Question about HP PSC Photosmart 2355 All-in-One Printer
HP 2355, power module light on but on/off light not illuminating. LCD screen lights but freezes and no mechanical action is noticed. Tried all common forms of reset to no success. Any ideas?
2005 f150 4x4 power windows ,interior lights a/c ,radio gauges are not working fuses are ok and already check for voltage and it has but still not working . It has something else in betwen..?......
Checked voltage where ?
The instrument control module (ICM) controls power to the power window system by activating or deactivating the delayed accessory relay.
Symptom Chart Condition Possible Sources Action
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • Instrument cluster module (ICM).
  • Accessory delay relay.
  • Driver window control switch.
  • Go To Pinpoint Test A .
Vehicles equipped with remote keyless entry (RKE) have an illuminated entry feature, which enables the instrument cluster module (ICM) to illuminate the interior lamps (and if equipped, the puddle lamps in the exterior mirrors) when an unlock signal is received from the vehicle security module through the UBP network, or when any of the doors are opened. The ICM controls the interior lamps illuminated entry feature by activating the battery saver relay. When active, the illuminated entry feature will be canceled when any of the following conditions are met:
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Defective Instrument Cluster Module REFER to Section 413-01 . B2499 Courtesy Lamp Output Failure Instrument Cluster Module Go To Pinpoint Test A . B2659 Courtesy Switch Fault Instrument Cluster Module Go To Pinpoint Test C . - All Other DTCs Instrument Cluster Module REFER to Section 419-10 . Do you have a professional grade scan tool ? If not your best bet would be to take your vehicle to a qualified repair shop .
Oct 23, 2016 | 2005 Ford F-150
My Phillips TV (42PFL7422D/37)light comes on to show power but the screen does not light up. It does have sound. Guy on line stated it most likely is the T-con board/LCD controller. That this is common...
Try to to put-off your lights and see if you have slight illumination on the screen, if it does, its the t-con board. If totally none, you have to change your Inverter board.
Jan 19, 2015 | Televison & Video
What is the difference between the flash and continuous lighting, why not using continuous lighting for photography?
Two main reasons flash is used over continuous lighting.
Power. Lighting a scene for minutes uses much more power than lighting it for a fraction of a second. You may have noticed that most continuous lights need to be plugged in to a power supply, while most flash units work with small batteries. It may not make much difference if you're shooting indoors in a studio, but if you're out in the field and have to move around, it can get difficult lugging all that gear around.
Duration. A flash unit provides a very brief flash of light while a continuous unit is, well, continuous. A flash can freeze action much better than just using the camera's shutter. Try it yourself sometime: turn on the lights in the bathroom (and/or bring in your continuous light units) and take some pictures of a dripping faucet. Now turn off the lights and take some flash pictures of the same thing. See the difference?
Dec 17, 2013 | Photogenic DigiLight Continuous 500 watt...
HP PSC 2355 does not "boot up".
Is it connected directly to the wall socket for the power supply or thrugh a surge protector.. if its through surge protector try connecting directly to the wall jack ..
Oct 19, 2009 | HP PSC 2355 All-In-One InkJet Printer
I have a hp2000 with a black display screen
your problem is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google
Aug 20, 2009 | Dell Latitude D600 Notebook
My rca L26WD26D does not power on - using the remote or the direct power button brings about the same results. The green light comes on and clicking is heard, then the red light comes on. This cycle is...
The most common failures with LCD/ DVD combos is a failure in the DVD transport mechanism. The DVD transport mechanism is an easily replaced subassembly, that can be purchased for less than $200 in most cases. The best bet is t replace this mechanism ensuring that you purchase it from a vendor who will purchase it back if it dos not fix the problem for some reason.
In the event that the DVD player replacement does not solve the problem, the second most common problem is LCD's is the power supply module. Assuming that you do not want to have a shop repair this unit, search for a power supply module online and replace it yourself, ensuring you can return it if it doesn't resolve the problem.
There are other things that cause that symptom on LCD tvs that are beyond the scope of this discussion.
Apr 29, 2009 | RCA L26WD26D 26 in. LCD TV
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
Sharp 42" flat screen LCD T.V.
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Feb 22, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HP PSC Photosmart 2355 All-in-One Printer Logo
232 people viewed this question
Seeker5211
Seeker5211
