FixYa.com
Tags:
Air Conditioners
Generic problem for all Air Conditioners
My a/c unit will not come on
posted by hhpsdl on May 17, 2008
The entire a/c unit will not come on at all. The air compressor, fan, heat none of it will come on. It is getting power to it. What could be the problem? It mearly just stopped working with no obvious reason.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 17, 2008
Not Rated (0)
22yooper
Rank:Guru Guru
Rating: 85%, 349 votes
If you have a digital thermostat check the battery. After you change the battery switch the fan to the on position. The fan should come on. If it does not the transformer that supplies the voltage for the control circuit could be bad. Check the fuse at the air handler and the off/on switch also to make sure it is on at the air handler (Furnace).
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE (APH10AA) Air Conditioner GE AGM24DJ Electronic Room Air Conditioner w/ 23,600/23,150 Cooling BTUs & Electronic Thermostat GE APN10AA Portable Air Conditioner Coleman Mach III Air Conditioner GE Â 230/208 Volt Built-In Room Air Heat/Cool Unit Air Conditioner Panasonic 9,800 Btu Room Air Conditioner with Touch Controls and Remote Control, CWXC104HU DeLonghi PAC85 Portable Air Conditioner
Can you Help with these Air Conditioners problems?
Air Conditioners
Through the wall airtemp air...
Air conditioner is blowing air... Answer This...
Air Conditioners
Coleman outdoor air cond. unit
Coleman outdoor air cond. unit... Answer This...
Air Conditioners
won't cool
won't cool Answer This...
Air Conditioners
I need wireing schematics for
I need wireing schematics for... Answer This...
Air Conditioners
Gas Furnace locks down in
Gas Furnace locks down in half... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
