Question about Hotpoint Refrigerators
I have a hotpoint ff93p fridge freezer and the fridge is running at plus 23 the repairer has charged me 95 pounds to change the two small wired parts (temperture controls) in the freezer and has not solved problem as freezer is not going down to -22 as nomal do you have suggestion
  • 50 Answers
You may have a defrost problem. It could be either the defrost control itself or the defrost heater. You would have to look at your evaporator coil to see, if it is frozen solid. If the evaporator fan working? It should stop, when the freezer is in defrost. If it never starts, either the fan is broken or your defrost control is stuck.
Posted on May 18, 2008
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Hotpoint washer wt640 front filter cover stuck
We had to use brute force, pliers and lots of wiggling back and fore. When we eventually got it out, about a pounds worth of small change and lots of gunk blocking the way.
Spin now working, f05 gone. Very happy as hotpoint wanted 95 pounds for a call out.
Good luck all.
Jul 29, 2012 | Hotpoint Washing Machines
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
Jun 03, 2012 | Hotpoint Refrigerators
Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Jan 10, 2010 | Miele KF7642S Bottom Freezer Refrigerator
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Wiring diagram for a Hotpoint FF73P
I am having a problem Fridge Freezer hotpoint ff73p
my fridge temperature is +23 need help
Oct 25, 2008 | Refrigerators
My hotpoint mistral fridge/freezer is freezing very will, but ther fridge is not cooling. What could be wrong?
Hi. I had the same problem (funnily just as my warranty had run out) hotpoint wanted about £90 plus parts for a call out. You need to replace the Yellow thermistor in the freezer compartment (quite easy with a cross screwdriver and thin fingers). I got mine from Uk White Goods for about £20 they give advice too. Solved it instantly. Thanks HOTPOINT, wont be spending £600 with you again. Good Luck.
Jun 20, 2008 | Refrigerators
Hotpoint fridgefreezer FFS70
if you have no cooling at all it means that a no gas charge b locked  in defrost c thermostat d compressor not working
Oct 30, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
98 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
