Question about Samsung ML 2010 Laser Printer
The printer does not respong to a print from computer command The on-line/error red ligth is flashing The toner save green ligh is flashing It does not pooduce a sample page if I press and hold "Cancel" williamstoddart@gmail.com
  • 3,083 Answers
The computer is not communicating with the printer. A cable could have come ajar, or a driver in the computer could have failed. Check your cables to the printer, and make sure it's turned on. Go into your control panel, and printer and make sure you see your printer there. Click on the Samsung and make sure under ports that usb is selected. Also, go into your device and hardware settings, and ensure your usb ports are recognized. If they aren't, update the drivers or reinstall them.
If you don't see your printer there, reinstall your CD that came with it. You may have to try this anyway, if nothing works.
Other than getting the software reinstalled, there may be a problem with the printer, and you might run it by a computer shop or hook it up to a friend's computer, to see if it's detected and works. Then you'll know whether to have it serviced, or if you have to install a driver from the CD or the net. You can get drivers and help here at Samsung Support:
http://www.samsung.com/us/support/
Here is another site for drivers:
http://www.nodevice.com/search/search.html?text=Samsung+ML+2010&search_area=all
Good luck, and hope this helps.
Posted on Sep 16, 2010
Samsung ML-1710p - when attempt to print, leds start slowly blinking simultaneously, "on line / error" - red, "toner save" - green
May be rejected this toner unite or paper could not feed properly.Service thoroughly your printer and Fuser unite.
Nov 27, 2009 | Samsung ML 1710 Laser Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
On line/error and toner/save lights on
try to find some jam paper inside your printer or try to re-insert the toner cartridge....
Oct 26, 2008 | Samsung ML 2010 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Samsung ML 2010 Laser Printer Logo
41 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
