Question about Intertherm Heating & Cooling
A/c unit won't come on
The entire unit will not come on at all. The air compressor, fan, heat are not working. It does have power to it.
    Scholar:
  • 57 Answers
Do you have a low voltage fuse in the Air Handler?
The fuse could have blown if there is a low voltage short in the system. The low voltage system powers the Thermostat.
If no fuse the transformer may be bad. Or the Thermostat may be bad. Or it could be a tripped float swith which means the drain line is plugged and overflowing the primary pan into the secondary pan. Nothing runs if the installer broke the red wire to the switch. It's always a good idea to keep the drain line clear. this can be done by finding the location to where it comes out on the outside of your house. use a wet and dry vac on the line or even back flush with a garden hose just make sure you use a very short count to 5 when flushing. You do not want to flood the primary pan you just want to cause a vaccume on the line with water.
Posted on May 17, 2008
    Scholar:
  • 149 Answers
If unit uses a manual switch to turn on suspect it faulty if a circuit board is used the main fuse blew out.
  • Alexander  Figueroa
    Alexander Figueroa May 17, 2008
    also try looking at the condition of the combination capacitor it can be faulty too
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: my a/c unit will not come on
If you have a digital thermostat check the battery. After you change the battery switch the fan to the on position. The fan should come on. If it does not the transformer that supplies the voltage for the control circuit could be bad. Check the fuse at the air handler and the off/on switch also to make sure it is on at the air handler (Furnace).
co7196
  • 3433 Answers
SOURCE: Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: split unit, I get heat but no cold
check for a signal on a demand for heating at the ondensor and thermosat
Posted on Oct 20, 2012
Wiring diagram for dometic a/c model600312.331c
Assuming the fan has only one speed. Remove the two leads going to the fan and connect them directly to the incoming power to the entire unit on the switch side, that way soon as you turn on the unit the fan will also come on, but not go off until you shut down the unit. Just make sure the voltage required by the fan and the supply voltage to the unit is the same.
Aug 20, 2014 | Dometic Rooftop RV Air Conditioner
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Jun 07, 2013 | GE Zoneline AZ55H07D Air Conditioner
Pro Standard Fan mount
Since the failure of an air conditioner to turn on, loss of air conditioner cooling capacity, reduced air conditioning output temperatures, loss of cool air supply, or even loss of air flow entirely can be due to a variety of problems with one or more components of an air conditioner or air conditioning system, after reviewing the lost air conditioner cooling diagnosis procedures described in this article, be sure to also review the diagnostic procedures at each of the individual air conditioning diagnosis and repair major topics listed just below. To return to our air conditioning and refrigeration home page go to AIR CONDITIONING & HEAT PUMP SYSTEMS.
Electrical problems on HVAC systems: Keep in mind that despite the depth of technical detail you will find here about all components of air conditioners and heat pumps, most service calls for non-working air conditioners or heat pumps turn up an electrical problem. So if your A/C system is just not working at all be sure to check all of our electrical and control setting suggestions first.
Mechanical problems on HVAC systems: tend to fall into these groups: refrigerant leaks, dirty condenser coil or unit, dirty evaporator or cooling coil, or burned out (or hard-starting) compressor motors. We have also seen a number of problems with fans and fan motors in both the compressor/condenser unit and in the air handler/blower fan unit. Some of those fan problems are mechanical - like a loose fan belt or blade. MORE DETAILS
Nov 13, 2012 | Heating & Cooling
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
Older Haier model...hd074cw (?) Does not pull water from air into bucket. Just stopped working this summer. Compressor and fan both working. What else can I check??
If the compressor and the fan are working then the next thing is to make sure The entire unit is cleaned . This may require you to diassemble the unit . The refrigerant Coils must be clean in order for the compressor to shed heat and propperly function. Once the unit is cleaned out thoroughly, if you still have problems you could be low or Out of refrigerant. If so it usually does not make financial sense to replair these unless It is a very expensive(over$500) model. You would be better off to replace it.
Aug 09, 2011 | Haier HD656E Dehumidifier
Freezer is ok, but fridge is not cold enough
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
Sep 01, 2009 | Kenmore Refrigerators
A/c unit not working
So only fan is running, the compressor not running okay check the voltage going to the compressor. The connection is coming from Thermostat or temperature controller, if there is supply going to A/c Comp. check the safety thermostat relay above the compressor.
Jun 01, 2009 | Heating & Cooling
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
My a/c unit will not come on
May 17, 2008 | Heating & Cooling
Heating & Cooling Logo
98 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
