Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer doesn't get hot anymore. - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 16, 2010
Kenmore dryer MOD# 110.61402310, Dryer heats up and is SUPER hot. Clothes are to hot to take out after. Seems like timer is messed up because it will run until you open the door. Only has one heat set
OVER HEATING HAPPENS ONLY IN ELECTRIC DRYERS NOT GAS DRYERS.... HERE IS A VIDEO FOR HELP ON THIS..
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 28, 2014 | Dryers
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
I have a whirlpool le6150xsw1 dryer and its not getting hot
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 28, 2012 | Dryers
Hi there, I've got a Whirlpool dryer that doesn't dry clothes anymore. The clothes get really hot, but they stay damp, never properly dry after several cycles and then smell mouldy. Oddly,...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 05, 2011 | Dryers
_don@hotmail.comthe heat control function doesn't seem to be working, the clothes get very hot regardless of setting. which device controls the temperature? Thanks for your help. Don
Hi ngentry don...
Your overheating problem is not caused by the thermostats...
Do the following:
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
My dryer runs and heats up but doesn't dry the clothes. i noticed some dampness on dryer door when i open it. the clothes circulate but don't fully dry. i noticed the dryer is heated and light is...
Hi mandolins23...
Sounds like your venting system is plugging up, try these suggestions below...
Aug 30, 2011 | Kenmore 600 7962 Dryer
I have a Whirlpool WED 7300 Dryer and it keeps beeping during drying, Help
I had the simmilar problem when I heat load of sheets, I guess maybe it is because it is getting too hot inside the dryer, so I set the cycle to manual and adjust the temp. to low, it doesn't beep anymore. hope it helps.
Aug 03, 2010 | Dryers
My maytag clothes dryer does not get hot anymore.
is this an electric dryer? if I had the model number, around the hole where you put the clothes in, I could tell you better if this is something you can do yourself. it may not be the heater, it could be a thermal fuse cutout giving you trouble. let me know.
Oct 13, 2009 | Maytag Dryers
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
