posted by Araboer on May 17, 2008
My fuji s7000's lens got stuck with a zoom error. Is it software? Then where do I download it from? Is it hardware? What should be done? Kindly advise.
Regards
Dirk Coetzee
Best Solution
posted on Jul 05, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Hi
Mine did this and refused to function.
Take the batteries and card out just in case.
I then took out the 6 screws in the lens shroud (3 sets of two - note 1 long one and 1 short one for each set) and removed the shroud cover to one side. The lens barrel is located in the inner shroud and has a very close tolerance. This is the main cause of the problem as an dirt or dust just clogs up the fine tolerance. Try and jiggle the lens shroud slightly and if need beapply a little lens cleaning fluid in the clearance gap. Put batteries back in the camera and try to start the camera. The lens should move as normal. Keep perservering as this will solve the problem. It is only dirt stoping the lens from moving combined with the low power of the motor powering the lens focusing. Take care at all times and be sparing with any lens cleaning fluid.
Best of luck
DK
Best of luck
DK
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 18, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
there is 6 small screws
Solution #4
posted on May 17, 2008
This can be 2 different problems. First is low battery condition, early models of this camera had power control problems, ie battery can still be drained even though camera is off. If you know your camera has good batteries, you can try this if you feel brave: unscrew the 3 small screws at the base of the lens, this will allow lens shroud to come off. You can then extend the lens manually simply by twisting it. Leave lens fully extended, reassemble lens shroud, then turn on camera. Lens should reset.
If you dont feel confident in doing this yourself, visit a qualified camera shop, they should know all about this problem.
Comment by MarkDay, posted on May 17, 2008
As a note, if you suspect your camera has the first problem, battery drains even though camera is off, Fuji can do a firmware update which fixes this (for a price). Fuji does not provide firmware for download, bummer.
If its the second problem and what I suggest fixes it, it will probably happen again. Best I can recommend is to not use it when the battery gets low.
Suggest a new solution for this problem
Post a New problem for Fuji FinePix S7000 Digital Camera
Email this problem
Email this problem
Can you Help with these Digital Cameras problems?
CCD failure on Finepix s7000
so what is the solution to... Answer This...
Initializing picture cards for...
I just need to know how to... Answer This...
Fuji Finepix S620 image via LCD...
My Fuji Finepix S620 has been... Answer This...
My camera isnt working properly
Even Though The Battery Was... Answer This...
How do I replace the battery...
Can someone tell me how to... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
