Question about Dell Inspiron 1720 Notebook
My Dell Inspiron 1720 will not shut down and won't let me back in...even if I switch off the machine and reboot. I've even switched it off for several hours and tried to restart but the problem prevails. What might be the issue and how can I remedy? Gordon W. Whittet
5 Suggested Answers
  • 132 Answers
SOURCE: My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
Posted on Feb 21, 2010
  • 18 Answers
SOURCE: spilt drink on inspiron 1720. after letting dry
Make sure you DO NOT plug in your lap top to the power out let. This could cause a shock.
You see the Dell media direct, means your CMOS is OK.
But if Windows is not loading means the spill could have damaged your hard drive. I would strongly suggest you take it to a shop where they repair laptops.
This way you may have to replace your hard drive, but save your note book.
Posted on Jun 25, 2010
  • 629 Answers
SOURCE: inspiron 1720 reboots randomly. tried reseating
most likely related to the blue screen issues. a possible reinstall of the OS may be needed. To check if it is blue screen related, restart the computer, press F8 when system restarts, then select the option to disable auto-restart option on the advanced options menu and press Enter. Next time you use the system, see if it will still auto-restart or if you'll get a blue screen. If there is an error, a system rstore or OS repair or reinstall may also be needed.
Posted on Sep 11, 2010
owescrow
  • 24 Answers
SOURCE: umy dell 1720 inspiron keeps rebooting, when the
I had this problem a while back and it turned out to be a faulty hard drive. I had called Dell and done all of their troubleshooting to no avail. At first I thought it was a power source problem as that had happened to me with an old desktop I had, but it turned out to be the hard drive. If you are still under warranty with Dell, they actually are pretty good with customer service. I called them at 4:30 one afternoon and no kidding, I had the new hard drive by the next day. It's not always that fast, but it sure is faster than most tech support! I had to replace a keyboard, too, and got that in a hurry.
I would recommend at least calling Dell...they will run you through a number of trouble shooting scenarios. Then you will know for sure what it is, but I would bet it is the hard drive.
Posted on May 04, 2011
Can't connect wirelessly from inspiron 1720 to canon pixma mx 882
Hello Kamar,
Is your 1720 hard wired to your router? if so, you may not have the WiFi switched on on the PC. Do you have 5 vertical bars in the bottom right hand corner of the screen? If not, you need to switch the WiFi on with the switch at the front of the left hand side panel. o
Once WiFi is active, make sure the printer is on and in WiFi setup then install the printer software on the 1720 and follow the instructions.
I hope this cures the problem.
Kind regards,
Ron.
Nov 24, 2013 | Dell Inspiron Computers & Internet
Dell Inspiron 8500 won't shut down, on/off button doesn't repond
Hold down the ON/OFF button for several seconds until it shuts off.
Mar 04, 2013 | Dell Inspiron 8500 Notebook
Dell laptop 1720 inspiron not shutting download
Take out the battery and make sure that it is all the way off. Restart it after 5 minutes. See if it does it again. If it does try holding down the power button for ten seconds and see if it shuts down alll the way
Feb 03, 2013 | Dell Inspiron 1720 PC Notebook
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
My Dell Inspiron 1720 works with the battery, but shuts down when the ac is plugged in. Is there a simple fix?
Will the Notebook work with the ac plugged in and the battery out. Most of the time it will be a faulty charger or even the port the charger plugs into. The port is soldered to the main board and would be something that a repair shop would need to replace. If you search the www you can find Dell compatible power supplies for Dell at less cost than direct from Dell
Dec 12, 2010 | Dell Inspiron 1720 17" Widescreen...
Inspiron 1720 reboots randomly. tried reseating ram and cant find solution. the reboot happens usually when i try to use programs and just shuts down and restarts like nothing happened. help is very...
Sep 11, 2010 | Dell Inspiron 1720 PC Notebook
Hope this helps!
Feb 21, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1720 reboots while in use very frequently
Get it re formatted completely and doing a new partition.
Sep 12, 2009 | Dell Inspiron 1720 PC Notebook
Can not shut down. It stuck in the middle of and does not respond on anything
Take out the battery(the black thing on the back) and put it back in. Then turn the computer back on.
Aug 06, 2009 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
Dell Inspiron 1720 Notebook Logo
220 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
