Question about Whirlpool AKZ159IX Oven
Oven won't switch on, has the word STOP on the screen, was working until mains were switched off to repair a boiler.
I have no manual for the AKZ104/IX . The oven had to be switched off at the mains and I can't get the oven to go back on again...Please help!!!
Please email me at, angelaleary@ymail.com
Kind regards
Angela
Posted on Oct 26, 2010
I have a westing house 509 fan force oven the fan turns off when i turn oven off but the element still goes and goes and goes why
This sound like a switch problem, when you say turned off is the element glowing because the oven light is not working, or it has to be switched off at the mains switch to stop heating, could you clarify.
Nov 03, 2014 | Ovens
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
Fault code Close door (S) keeps coming and oven won't start
The oven is telling you that the secondary switch is not working. Either the switch is broken or the door or switches are out of alignment. the switches cost about 4 dollars. Not an expensive repair by any means.
Sep 09, 2012 | TurboChef TORNADO Electric Oven
Oven does not work! temperature display goes very fast and won't stop to higest temp
You have a bad control board and oven temperature sensor. I highly recommend disconnecting the power source until the repair is made.
Apr 24, 2012 | Thermador Ovens
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
Turn it on at 350degrees it won' ignite and eat but will work on boiler
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 24, 2011 | Ovens
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
Whirlpool electric oven
hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
Nov 30, 2007 | Ovens
Whirlpool AKZ159IX Oven Logo
449 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
