I think you can try this steps and hope it will help you.
Try to reseat the Wireless Card in your machine.
You will need the following tools to complete the removal and replacement procedures:
-Magnetic screwdriver
-Phillips P0 screwdriver
-5.0-mm socket for system board screwlocks
-Flat-bladed screwdriver
-Tool kit-includes
Turn the machine upsidedownRemove the battery.Wireless Card Removal1. Loosen the PM2.0×5.0 screw 1 that secures the Mini PCI
compartment cover to the computer.
2. Lift the rear edge of the Mini PCI compartment cover 2, and
then swing it forward.
3. Remove the Mini PCI compartment cover.
4. Disconnect the wireless antenna cables 1 from the Mini PCI
communications card.
5. Spread the two retaining tabs 2 that secure the Mini PCI
communications card to the communications compartment
socket. (The board rises up).
6. Remove the wireless communications card 3 by pulling the
board away from the socket at a 45-degree angle.
**Reverse the above procedure to install a Mini PCI
communications card.If happens that it does not work, I think you can just reinstall OS just to make sure if its Hardware or Software problem.
Thank you for choosing FixYa.
