Question about Gaggia Syncrony Espresso Machine
What dos it mean descalcify? - Gaggia Syncrony Espresso Machine
    President:
  • 1,618 Answers
It means removing the mineral buildup in the machine, here are some instructions to do so;
Posted on Sep 16, 2010
What dos vvt system malfunction it mean ?
Variable Valve Timing System Malfunction, and possible causes - dirty or low engine oil
- Valve timing
- Oil control valve
- Variable Valve Timing controller assembly
- Engine Control Module (ECM)
Read more: http://engine-codes.com/p1349_toyota.html#ixzz38fIMYdTd
Jul 27, 2014 | 1999 Daihatsu Sirion
Tip
Saeco
descalcified every 3 month the machine will last longer
on Jul 18, 2008 | Saeco Magic De Luxe Espresso Machine
It's impossible install MBR, How I can get install?
If this MBR mean, Master Boot Record, it's a DOS-alike thing.
You require a DOS or Windows 95 / 98 bootflop, containing the program FDISK (forgot if it was .com or .exe)
After booting you get the DOS-prompt which is text-based and looks like :
"A:>_" or "C:>_"
Now, in this case you enter the following: "fdisk /mbr"
So the DOS-prompt will look like :
"A:>fdisk /mbr" or "C:>fdisk /mbr"
Then you hit the ENTER-button at your keyboard and if DOS can find this fdisk-program, it will rewrite the master boot record of your harddisk.
Oct 11, 2013 | Toshiba Computers & Internet
How do you turn on and off dos mode
Do you mean by DOS mode, access to the terminal for command line interface? DOS is specific to PCs. The Mac equivalent is Terminal.
Go to Finder » Applications » Utilities » Terminal
Nov 03, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have blue dos on my sony wega. Does that mean I
Does the blue dots show even without picture? if so, defective optical engine.
Dec 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I need to download a program that requires windows and my computer says the program wont run in dos mode how do i get it to work?
if the program requires windows that means it was design to work with windows and not with DOS.. you may want to get an old version of the program that will actually run under DOS.. usually you may be able to do the opposite which is to run DOS program on windows.
if possible try to get a DOS version of the program you are trying to run, or better.. upgrade your operating sytem so you can run your program and possibly other DOS programs.
post the program you are looking to download and confirm what operation system you're running and I'll try to look for it with you.
Sep 27, 2008 | Acer Computers & Internet
Graphics devlopment
sorry vishu Micro Soft Vista is not going to support full screen DOS mode in any mean.
Thanks
Iqbal
Mar 30, 2008 | Microsoft Windows Vista Ultimate Edition
Coffee out not same as amount of water in/no steam
you have to descalcify the machine not with vinegar .vinegar removr calcium in little pieces and might block the machine descalcifier melt the calcium on the heating element you have lots of calcium that mean less heat you use 1 part descaler 1 part water put in water containerstart the machine for a few second turn off for 10 minute if you never descaled the machine leave it for 15 minute and repeat untill empty rince very good a few water container that stuff is very corosif after a good rinse try the coffee it should be good thank you for using fixya pierre
Feb 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Coffee tastes burnt/No steam for froth
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Feb 03, 2008 | Mr. Coffee ECM20 Espresso Machine
Gaggia Syncrony Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
