Question about Broan-NuTone Best by Broan K260A90CMSS Stainless Hood
Hood operates very loudly - Broan-NuTone Best by Broan K260A90CMSS Stainless Hood
  • Broan-NuTone Master
  • 43,501 Answers
Often the dirt and grease will build up on the fan/blower wheel and then some of it will come off throwing the wheel out of balance... this creates an intense vibration of of course a lot of noise...
Take the hood apart and clean everything really good and check the motor bearing to make sure they are not bad...(loose motor shaft in and out or up and down)...
Then you should be quiet again...
heatman101
Posted on Sep 16, 2010
Loud buzzing sound
That sounds like the starter motor solenoid chattering. This can happen when the battery is nearly dead and has only enough charge to repeatedly pull down the solenoid. Get someone to operate the key while you listen to the starter via a long screwdriver shaft or similar.
I don't know what the acetone smell could be. Another source here has mention a refrigerant leak from the A/C, but it is a guess.
Nov 04, 2013 | Honda Accord Cars & Trucks
The fans on this microwave will automatically turn on when I have more than one burner on the gas range going. The fan is horrendously loud and will not allow me to shut off for 2-3 minutes regardless if I...
That's typically normal operation. The microwave has a thermostat which turns on the hood vent exhaust fan at a certain temperature to protect the controller.
Your owner's manual will cover vent fan operation.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If - above and beyond this - the fan has a problem, that could make it excessively loud. Some are just loud though, it's hard to judge without actually hearing it.
You can contact Whirlpool customer service with your model number via that link above and ask them about the loudness. They may be able to tell by listening over the phone if it's abnormally loud.
Apr 28, 2011 | Whirlpool MH7130XE Microwave Oven
I instaled kenmore elite range hood but is too loud
They are all very loud... when you are moving air like they do it makes alot of noise...
heatman101
Feb 07, 2011 | Kenmore Kitchen Ranges
My 1997 chevy express has a loud screeching under the hood i changed my alternator 4 times already but the noice keeps coming back help.
you may only have a loose belt.it may not be the altenator belt,it may be another component thats bad. suggest you try starting the engine with hood up and look visually for a pulley thats not turning properly.or a pulley that wobbles.if you have more than one belt,look at all the belts to insure they are operating properly,hope this helps,if not,then please repost your question to fixya.com. there are experts online and ready to assist you!
Feb 02, 2011 | 1997 Chevrolet Express
The fan makes a very loud noise
the fan blade may be loose on the motor shaft there is a set screw on the blade center you can tighten (it needs to be very snug)
Aug 22, 2009 | Kenmore 51841 Kitchen Hood
02 Durango: loud engine/exhaust sound. Also Recently noticed the cooling fan running more than normal; had someone check the antifreeze/coolant....it was empty....had them put in a 50/50mix of coolant and...
That noise is probably the air injection system which is part of the emmision system. When it is making that noise, open the hood and determine where it is coming from, note if it is a mechanical sound, etc. The air injection if equiped would sound almost like forced air scaping somewhat like an exhaust leak, but less intense.
Jul 14, 2009 | 2002 Dodge Durango
Loud screeching under hood passenger side
How about checking the fan belts, they may need adjusting or replacing.
Jun 15, 2009 | 1999 Mazda Millenia
Kitchen Ranges Logo
363 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
