Question about Microwave Ovens
Where can I get a replacement Grease Filter for Delmore cooker Hood? I have model number. MN: GR04R
How to remove grease filter from a Samsung over the range microwave model number smh8165st
The support page for model SMH8165S is here, and the first solution listed is how to replace the charcoal filter.
You can also download your owner's manual.
The charcoal filter is part number DE63-00367A and you can order it from the Pros here.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
May 01, 2017 | Samsung Microwave Ovens
How do you remove grease filter from Samsung over the range microwave model number smh8165st?h
pupista@gmail.com
The right Half of the touch panel does not work and there is no power when start is pressed. Fans and lights work
Without a model number, I can only give you a general answer, but feel free to contact me with the full model number and detailed symptoms for a free estimate and/or do it yourself tips and part numbers, etc.
The problem is a failed keypad, which can occur due to manufacturing weaknesses, direct spraying of spray cleaners, heat or steam or grease accumulation due to failure to use the hood vent exhaust fan while cooking on the stove top, or just poor design.
Either way, you would have to replace the membrane keypad or outer door panel or control panel frame, depending on model.
Oct 05, 2011 | LG LMVM1945 Microwave Oven
How do i reset the grease filter indicator icon on the display on my arietta range hood
From the manual: To reset the grease filter saturation alarm the user must press the "+" key for 5 seconds, after this action the icon "grease filter" is not display [sic], and the hood has the normal display operation.
Feb 19, 2011 | Microwave Ovens
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
My spacemaker keep dripping grease on my wall, what should I clean?
I would suspect a clogged grease filter (which can be cleaned) and/or charcoal filter (which cannot be cleaned and must be replaced).
You can download GE owner's manuals and installation instructions here.
The manual will give you the details.
Also be sure the hood vent exhaust fan is working correctly.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I do not have the directions for a 5.6 cup Hitachi Rice cooker (the Chimeomatic. Could you send them to me: Rachel Schwendinger 7510 360th Street North Branch, MN 55056 rschwendinger@hotmail.com
It's best to include the model number (probably starts with RD or RZ) but here is where you can download several.
http://www.hitachi-hk.com.hk/index.aspx?nodeid=445&langno=1&UID=1085&param=UID%3D1085
Even if none of these is exact, one may be close enough to yours.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 15, 2008 | Microwave Ovens
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
