Question about HP Photosmart C7280 Laser Printer
HP C7280 has a black "stripe" when I copy or scan > I have cleaned glass, reset. I works perfect to print Help
    Problem Solver:
  • 8 Answers
You have to clean document glass from inner side, not only from top of side.
Posted on Nov 19, 2010
Why do i get thick black line(stripe) when scanning and copying with the hp 4315
Sounds as if you have dirty drive path for the paper. Printers are bad about ink leaking (especially if not used often) and cleaning well involves some disassembly. The ink is very messy so wear rubber gloves. Clean around print cartridges, rollers, and also the glass for scans.
Jul 26, 2014 | HP OfficeJet 4315 All-In-One InkJet...
Hp psc 1210 will print but not copy
Symtom that scan head might be faulty, remove four screws located at corners, take out flat glass unit, remove scan head, check any damages in driving mechanism, clean reading head, fix it back and check.. If no result replace scan head unit..
acsn head snap shot:
Feb 03, 2012 | HP PSC 1210 All-In-One InkJet Printer
Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Jan 13, 2010 | HP Photosmart C7280 Printer
Wont print black
This worked for me on C6180
Good luck and let me know
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
May 31, 2009 | HP Photosmart C7280 Laser Printer
HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 16, 2009 | HP Officejet J5780 All-In-One InkJet...
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Copier will not work correctly
try cleaning the scanner glass(both the scan bed as well as the scanner glass on the Automatic document feeder)..then clean the copper contacts on the cartridges......if it still does not work then You can try a reset on the printer using the # and the number 6,holding them down while plugging in the power cord at the back of the printer.it should work......
Jan 06, 2009 | HP Photosmart C7280 Laser Printer
Stripes on scanned photo
Do copies come out the same? How about when you print? If you get the stripes whenever the printer prints from the computer or copies, then you probably have a bad ink cartridge. If you get it only when you make copies or scan, then check for dirt on the scan glass. Clean it anyway with some commercial glass cleaner. See if that works.
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
HP Photosmart C7280 Laser Printer Logo
400 people viewed this question
Seeker5211
Seeker5211
