posted by exforge on May 17, 2008
she powers up and i can get some lights to come on but no power output ive checked everything. she just quit one day when i was listining to it. i wish i could find a trouble shooting guide or something to help i like to fix things myself. please help
Best Solution
posted on May 26, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Just another follow up, those are 10 ohm resistors not 920 like I'd thought. Marantz did some goofy things with the color bands I guess-brown black black red white-but they're 10 ohms for sure. Odd though because the other two right next to them are ten ohms as well-brown black black gold. Mine was biased a little hot, but I adjusted both channels to idle cooler and it works fine now.....
Rating Locked! (?) exforge has rated this solution as Helpful
Solution #2
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
OOPS-forgot to mention if your bias turns out ok after replacing any blown outputs, turn it off and resolder the collectors (center) pins of all 4 output transistors and turn it back on-should work but you'll need to recheck bias and dc offset. They appear to both be adjustable on the board sticking up on the top side-it's right in the middle and has 4 trim pots on it......
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Amplifiers and Preamps
Email this problem
Email this problem
This Problem Also Relates To:
Kenwood 500W Class AB Bridgeable 2-Channel Amplifier with Crossover
NAD T163 Amplifier
NAD C320 2-Channel Amplifier
NAD C352 2-Channel Amplifier
NAD S300 Amplifier
Sony TA-E9000ES Amplifier
Sony TA-FE370 2-Channel Amplifier
Can you Help with these Amplifiers and Preamps problems?
Sony TA-N9000ES 5-Channel Amplifier
Sony TA-N9000ES Flash light...
My Sony TA-N9000ES 5 channel... Answer This...
Sonance Sonamp 1250 12-Channel Amplifier
where'sthe reset for the 1250
I have been looking for it but... Answer This...
Repair Service
Find Amplifier and Pre. Repairman Near You:
