Question about Lite On LVW-5045 DVD Recorder
Can't make dvd's from my recordings
My hard drive is full and I've been trying to put my shows together to make one disk for the same show. I keep buying disks to put them on a disk and either it tells me the format is wrong or it tries to erase a brand new disk.I read somewhere that the disks that are made today are too fast for this recorder I'm trying to use. And if I do start to make a disk when I try to finalize the disk. It spits it out and ruined the disk because now it tells you invalid disk. I always loved my Lite On but now I'm so frustrated. Now I have to unplug it all the time because it gets stuck and won't do anything. Is there anyway to buy disks. That are compatable with my recorder. Maybe older versions of disks.
  • Lite On Master
  • 13,433 Answers
The recorder supports these formats
DVD-RW · DVD-R · DVD+R · DVD+RW
There shouldn't be a problem with the speed, maybe a compatibility issue with brands.
Also it might be your lens is dirty have you tryed a cd/dvd lens cleaner disk? dry/wet?
Posted on May 17, 2008
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
Dvd recorder hard drive not recognized when used as an external
Open Start menu
Click the right mouse button on Computer
On the pop out menu click on Manage
In the left hand menu click on Disk Manage
Your drive should show here if it is plugged in.
Delete all partitions
Now create a partition, format it how you want.
Mar 21, 2014 | Hitachi Computers & Internet
I'm installing a biostar a78ldm2s and everything turns on but I keep getting a read disk error on the hard drives that I try to use. I've tried 5 different hard drives and get the same result.
Hello here you can download a manual:
http://www.biostar-usa.com/app/en-us/support/download.php
By entering the right mainboard number.
Try to set the bios to factory settings.Load default settings.
And set the boot order: first boot device:dvd, second, the harddrive.
If you are using a IDE drive make sure its set as master.
A sata drive does not have that function.
Make sure the windows disk is clean and without scratces.
Here is a youtube video that shows you how:
http://www.youtube.com/watch?v=sMc5ukMguEo
Good luck
Nov 04, 2012 | Biostar A780L Motherboard w/ AMD Athlon X2...
My Sony RDR-GX300 DVD Recorder is suddenly only recording the 1st 15 seconds from the DVR. The entire show is on the DVR. I have tried discs that I've used before successfully & new DVD's.
1) pass the Disk cleaner buy to some radio schack, and test it
2) test the cable in another device, and determine if faulty or not.
3) if not clean the terminal from DVD VS TV with c.cleaner
4) otherwise the Syscom inside and another associates circuit is faulty such like record ampl.
go to the repair shop for fix it.
God bless you
Oct 01, 2012 | Sony RDR-GX300 DVD Recorder
Camcorder keeps reading internal memory full and just put new memory stick in camcorder how do I get out of internal memory
Your Sony camcorder has internal hard-disk and records by default to this media. If this is full, you need to offload the recordings and free up some space on the disk. But to select the memory card you can do the following:
Selecting the recording media for movies:
Touch (MENU) [Show others] [MEDIA SETTINGS] (under
[MANAGE MEDIA] category) [MOVIE MEDIA SET].
The [MOVIE MEDIA SET] screen appears.
Touch the desired recording media.
Touch [YES] .OK
The recording medium is now changed.
For still images:
Selecting the recording media for photos
[MANAGE MEDIA] category) [PHOTO MEDIA SET].
The [PHOTO MEDIA SET] screen appears.
Touch [YES] .OK
The recording medium is changed.
Hope this helps, if more help needed, reply back.
Apr 12, 2011 | Sony Handycam HDRXR350E High Definition...
How can I copy all HDD's data in LG HDD/DVD Recoder RH1888HS by my computer or Laptop?
If the unit is under warranty...DON'T DO THIS.
open up the unit and remove the hard disk.
If you have a desktop, connect the drive like you would any other hard disk.
If the drive does NOT show up under My Compujter, then the format is proprietary, and all you can do is back up the drive with a program like Acronis True Image (you must have more free space on your hard disk than the DVR's drive size...if the DVR has a 500G hard disk, you need 500G of free space on your desktop drive).
If the drive DOES show up with a drive letter under Computer, then create a directory on the C drive and simply drag and drop all the files from the DVR hard disk (E: or whatever it makes itself) to this folder. The files may still be in a proprietary format and unplayable though.
If you are trying to play the files on the computer, I suggest using VLC player. It plays almost everything in the universe.
Mar 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I have a jvc SR-DVM70 - The hard drive is about 75% full of data so I don't want to lose that. The deck was working fine recording through the firewire to the hd. Problem was it didn't playback through the...
The hard disk hasn't been recognized in Windows because the JVC runs Linux so the drive was formatted in EXT3 which Windows can't read.
Simple fix to recover all your data: connect the disk back to the pc and boot from a Linux Live-CD like
http://pclinuxos.com/
In there all you have to do is to copy all the content of the disk to your local disk (PCLinuxOS can read and write securely on NTFS/Windows disks). Or you could just burn them to some dvd's.
For the rest: 1 - on the CS pins; 2 - no.
Jun 25, 2010 | JVC SR-DVM70 DVD Recorder
Dvd dmr-xw350 Hard drive full If you try to record, you are messaged that you have to delete programs to make room for future recordings to work - thats OK, I have done this before filling the Hard-drive....
I cannot help with your problem but unfortunately the same thing has just happened to me this morning. I woke up and every recording is apparently gone, but I cannot record because it says there is no room on the HDD and for me to delete titles. Can anyone help!?
Jul 07, 2010 | Panasonic Televison & Video
Hard drive shows full even after erasing 120 hours.
You should empty the recycled bin in the system and delete all temporary files on it.
Jan 10, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Lite On LVW-5045 DVD Recorder Logo
187 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
