Manual for rex rotary 2238 aficio - Office Equipment & Supplies
  • 37 Answers
SOURCE: REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Posted on Aug 14, 2008
idriss47
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
SOURCE: Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
Posted on Apr 30, 2009
  • 5 Answers
SOURCE: Rex.Rotary MP 2510
ricoh ft 5832 is not a digital copier therefore cannot connect
Posted on May 31, 2009
Ezrahite
  • 2632 Answers
SOURCE: rex rotary aficio mpc 3500 touch pad screen is not
Welcome to Fixya. If the touchpad is not working it only means one thing. It means that the touchpad panel is bad and the only way to fix this is to have it replaced. If you can check the warranty of the device so that you can bring the machine to a service center and have the part replaced for free. This is not a quick fix since the touchpad is the main control of the copier. A Service tech can provide you the information if there are other parts that are affected other than the Touch pad.
Thanks
Posted on Aug 11, 2011
Copier mp3500 rex rotary ,i want to remove the authentication ,it displays sc548 contract serial no of march M2772901444
This a fuser (hot section) error code that need you to enter service mode to clear, -Carl
Jun 04, 2010 | Ricoh Aficio 450 Copier
RICOH 2238 C ERROR CODE SC680
SC 680 BCU/ MUSIC communication error After the engine CPU sends a message, the Music CPU does not respond within five seconds three consecutive times. • Toner cartridge memory chip loose connection • Memory chip problem • Memory chip cable wiring problem 1. Turn the main switch off and on. 2. Check if the toner cartridge is installed correctly. 3. Replace the toner cartridge. 4. Check if the harnesses are not damaged. 5. Replace the BCU.
Mar 12, 2010 | Ricoh Aficio Type 2238 (411603) Print...
I need a Widnows 7 64bit Fax Driver for a Ricoh 1515mf network copier, is there a work around to get this to work
try this site www.nrgcss.com
your machine is rex rotary --Dsm415
check if there are any compatible drivers
Jan 13, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Rex.Rotary MP 2510
May 02, 2009 | Ricoh FT5832 Copier
Apr 30, 2009 | Office Equipment & Supplies
Ricoh rex rotary sc 548
Hello wajidsn
Jan 07, 2009 | Ricoh Aficio 450 Copier
I need the software to scan from Ricoh Aficio 1075 Please help me! thanks alot.
download rex rotary 7508
copy-paste link
http://www.nrgcss.com/drivers/Page2.asp?Brand=rex&Vw=&Fltr=0&Ky=346675716&Usr=&Cat=3&Pvw=1&Mdl=145
Nov 15, 2008 | HP PSC 1315 All-in-One Printer
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
SC542 code appears on my Rex Rotary 2822, give solution please
This means the fuser has an error. You can not reset the code even if the fault has passed without entering the service mode. If you need a service manual for this let me know and I will send you a link.
Apr 21, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Toner lines when I print
I don't think it is anything to do with the toner cartridge as this doesn't put the toner on the page seems to me that the drum unit is faulty either the cleaning blade has failed or the charge roller. Best thing to do is call a service engineer or copier company that deal with Richo or Rex Rotary.
Thanks J
Nov 18, 2007 | Ricoh Aficio 180 Laser Printer
239 people viewed this question
jasbo
jasbo
