I have and extern hard disk Store & save 2400 packard bell but i cant find on my computer
  • 24 Answers
SOURCE: packard bell easynote l4014 display
Right-click an empty area of the Windows Desktop (your main screen). Click Properties, then the Settings tab. Under the slider labeled Screen area or Desktop size, slide the slider and click apply until you find the size that takes the fuzziness out of your laptop display.
Hope This helps!
Posted on Jan 31, 2008
voodoomox
  • 1689 Answers
SOURCE: How do I get the
the enclosure is locked but clickers, the only way to oepn it is by force since PBell has a specific pressure point on the enclosure to open it.
the ratling sound means that the disk in your HDD is not alligned, it could just be a matter of time before it completely looses railing and be unusable.
best move you can do is contact PCBell and have them informed about your issue.
good luck
Posted on Jul 23, 2008
  • 6 Answers
SOURCE: retrieving information from my external hard drive
Check to see if you can see your drive in DOS. To start ...run ...type in CMD and hit return. Then type E: (it should be the last drive letter...if not e: try F: etc..).....and return ...then type DIR and hit return....can you see the files on the drive ? might be security software you have running or it might be one of the Microsoft services not running....try the above 1st it should prove if its a windows problem..
Posted on Mar 30, 2009
  • 82 Answers
SOURCE: easynote will not go past packard bell screen
You may need BIOS update. Check your CMOS time at bios page.
If time is wrong, set it up and try again. If this is solved the problem, change the CMOS battery.
JMC
Posted on Aug 15, 2009
  • 5 Answers
SOURCE: cant see hard drive.systems & boot disc cant
U can try by checking for it iin the bios..
Posted on Sep 14, 2009
I have a Packard Bell Store and Save Model HD D2 U2. I have not even used much of the space, but i remember trying to download a trial copy of photoshop cs5 on to it. After the exercise the external HDD...
It's hard to say from your description what the problem is but the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Aug 30, 2011 | Computers & Internet
I have a Packard Bell Imedia desktop not sure of the model. It was working fine until recently, I switched on my pc and after the boot screen "NTLDR is missing Alt Ctrl Del" message appeared....
Remove the hard disk and attach it to an USB hard drive adapter and then connect it into the USB port of a working computer. This computer will detect the hard drive as an external storage device, then you can open the various folders and files to copy your files to this computer or burn your data to a CD/DVD disc or USB flash drive.
Return you hard disk back to your Packard Bell so you can reinstall Windows.
Aug 10, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
I have a packard bell store and save 3500 250gb and it seems that it has packed it. i need to get the files of the hard drive how can i fix it?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 10, 2010 | Computers & Internet
Disk drive not working
If you are not facing any other issues other than playing the CDs, I would suggest you to go for an External Drive and get this issue resolved. In case you are facing many other issues and the computer you are using is not a Pentium 4 or equivalent, I would advice you to go for a new computer with better configuration.
Oct 05, 2009 | Packard Bell Computers & Internet
How do I get the cover off a Packard Bell Store & Save 3500 external hard drive as there is something rattling inside?
good luck
Jul 23, 2008 | Packard Bell Computers & Internet
Problem to start my external packard bell usb 2.0 250 GB hard drive
Sounds like the drive is dying. Is it externally powered, or powered through the USB port? How old is the drive? When you say 'strange' what does it sound like?
Jan 08, 2008 | LaCie USB 2.0 Mobile 60GB 5400rpm 480Mbps...
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
