Question about Marantz PM-68 Amplifier
Marantz PM-74D it powers up and i can get the lights to work but no sound or power being generated by the unit any ideas
  • ciara4 Oct 11, 2008
    Marantz-PM66SE Amp suddenly stopped working Power light on but no sound. Trouble shooting of manual no help. Have tried all the obvious solutions power switch, speaker cables, volume control ect with no joy. Please help
Your no doubt finding the speaker safety/turn on surge protect relay NOT engaging a few seconds after turning it on-right? Check the output transistors. These are the big green and black ones screwed to the heatsink. You gain access to them by taking off the bottom cover. There's 4 per channel--2 green and 2 black. You'll probably find one or more of them shorted. If you find replacements, put them in exactly as the originals with new thermal grease/heatsink compound. Unsolder and lift the center pin (collector) on each of the four transistors of the effected channel. Power it up and check across the outside pins of each device for proper bias-about a half a volt or so on each one. If the voltage is much higher, or not there you've got other problems that will require more diagnostic/troubleshooting. Do all the lights on the front panel work-or just the tape monitor indicators? If just the tape monitors light up, check resistors RN83 and RN84 on main board under the speaker connector board-remove the speaker connector board to get at them. These are bad on mine and I've yet to replace them. I believe these to be 920 ohm 1% precision resistors....
Posted on May 26, 2008
Marantz PM-66 SE: Power light comes on, but the amp does not work
try taking a flashlight and look through cover into unit for a blown fuse or take cover off (which is better) if taking cover off unplug unit. If a fuse is blown remove it and take to a store like Radio Shack for proper fuse watt and amp..if fuses are ok i would get it fixed...sounds like a minor problem since main power is there. GL
Aug 08, 2014 | Marantz Audio Players & Recorders
Marantz SR5005 power up
Sounds like a short in the amplifier. This will have to be repaired before the unit will operate.
Feb 22, 2013 | Marantz SR5005 Receiver
Hi, I have a Marantz PM 57 Amplifier that is not working. The power light comes on but no sound from speakers (nor headphones). Just moved house, and hadn't used it for a while (don't remember it not...
After a move and something doesn't work that could have before, it's always best to check inside for signs of damage. It might just be a bad soldering joint, so it could be just a small amount of damage.
Jan 14, 2011 | Cambridge Audio Azur 340A 2-Channel...
I have a Marantz PM-66SE Ki amp which appears to have a problem with one of the channels which is only outputing about 10% of the volume of the other channel. Have tried swapping speakers and cables around...
I have exactly this same problem with my Marantz PM60100SE - one of the channels seems to have lost power and is much much quieter than the other one.
Did you find a solution to this? Anyone have any ideas?
May 20, 2010 | Audio Players & Recorders
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Marantz PM-74D
OOPS-forgot to mention if your bias turns out ok after replacing any blown outputs, turn it off and resolder the collectors (center) pins of all 4 output transistors and turn it back on-should work but you'll need to recheck bias and dc offset. They appear to both be adjustable on the board sticking up on the top side-it's right in the middle and has 4 trim pots on it......
May 17, 2008 | Audio Players & Recorders
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
Marantz PM-68 Amplifier Logo
836 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
