Question about Dell E193FP 19" LCD Monitor
Dell e193fp monitor
When monitor is plugged in and powered on, the orange light on monitor comes on and laptop detects monitor. Nothing more is happening, can the monitor be faulty?
  • breytea May 17, 2008
    Hi, thanx for replies - the monitor is selected on laptop to be used as the extended one, the monitor does not want to switch "on" - green light on power button does not want to turn to green, it stays on orange, which makes me to think that the monitor could be faulty? I tried to disconnect monitor and not even the test signal on monitor wants to come on.
  • bert144 Nov 29, 2008
    My monotir was doig the same thing - going orage but never turning green and coming on. Now it won't turn on at all. It is past warranty almost 2 years old. Is there anyhing I can try on my own before I chunk it? The board looks fine, no visible burns or damage.
  • 242 Answers
To activate the monitor, right-click your desktop, click properties, go to Settings
Then click on the blue square with 2 in it. Now select 'Extend my Windows desktop onto this monitor'
Now click Apply
Change the screen resolution if needed, the monitor should work now.
Please post some feedback...
Posted on May 17, 2008
  • Thx_nb May 17, 2008
    OK, I'm pretty sure your monitor is defect then.
    You could double check by connecting the monitor to another computer. If it still doesn't work, it's defect...
    If warranty is valid, contact dell about repair or replacement.
Have you made sure the laptop is outputting the the monitor? Does the monitor have dual inputs? if so check it is switched to the correct one. With the laptop turned on and connected, switch the monitor on and off.
good luck
fridge
I have a Dell E193FP Monitor. The power light is green, but the screen is blank.
There are two cables connected at the back of the monitor. one for the power and one for the video . Make sure the one for the video is securely fitted.
Hope that helps.
Thank you.
Dennis
Sep 08, 2014 | Dell E193FP 19" LCD Monitor
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Where can I obtain a power supply for a DELL E193FP LCD Monitor, preferably new or used if that's all I can get ?
If you are talking about the power plug that goes to the monitor, it is a standard three prong computer power cord, and is identical to the cord on the computer.
The optional sound bar requires a power brick. It is a two part power adapter which has a large brick like piece with a power cord on one end and the rca jack on the other.
Jul 30, 2010 | Dell E193FP 19" LCD Monitor
My Dell E193FP boots up with the computer and then
Seems to be a very common problem with this screen. Im taking one apart as we speak to try to discover the problem. In the mean time - check that the Power Input isnt loose, and you can wiggle it around. Usually means the power is arcing onto the board
Sep 01, 2009 | Dell E193FP 19" LCD Monitor
Second monitor for laptop not working as plug and play
Go Here.
http://support.dell.com/support/downloads/download.aspx?releaseid=R83276&formatcnt=1&libid=0&fileid=109465
Download driver & install.
Hope this fixed ya. Please Rate.
If you need more help send comment & ill respond. Good Luck!
Mar 12, 2009 | Dell E193FP 19" LCD Monitor
Black screen on monitor when plugged in., no picture at all
When you plug in the monitor no lights come on at all green, orange nothing ?
Try
1. Using a new power cord ( maybe something is wrong with it)
2. Plugging it into a new socket on the wall.
If you can't get power to the monitor at all you may be in for buying a new one.
Jan 04, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Will the E193FP work with my computer?
I would suggest , check the monitor connections again. Dell flat panels are plug and play and donnot require additional drivers.
Make sure , you have not connected , both the analog (vga cable with a blue connector) and the digital (dvi cable with a white connector) to the back of your computer.
Refer to the the link below , to troubleshoot the monitor
http://support.dell.com/support/edocs/monitors/E193FP/En/trouble.htm
Thanks
Proton
Nov 10, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
Faulty monitor
Hi bakey 55 ,
Please click on the link below check whether you have connected the monitor in the same fashion or not......
http://support.dell.com/support/edocs/monitors/E193FP/En/attach.htm
You can also run a Monitor self test if the above set-up does not resolve the issue.(refer link below)
If the above 2 links does not help then call Dell technical support at 1-800-624-9896 TOLL FREE (USA)
Goodluck :-)
Jun 05, 2008 | Dell E193FP 19" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell E193FP 19" LCD Monitor Logo
266 people viewed this question
Alun Cox
