Question about Gateway 450ROG Notebook
After powering on there is an orange light that comes on above the power button. I cant really tell wht they symbol is, i cant get anything to work.
  • bibendum
    bibendum Sep 16, 2010
    ideally orange colour light means ,monitor is in sleep mode you could hit ESC key on keyboard or click the mouse
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Xbox 360 will not power on and the power supply has an orange light
Hi, try this
take out the power lead from back of xbox, turn power lead off at mains and leave unplugged from mains and xbox for at least 5 min,
plug it all back in but make sure you push the power lead into the back of the xbox really hard push it in the try hard to push it in further then plug it into the mains then switch on and press the on button.
if after trying that it still dont work try pressing the open button for the dvd drive as this will switch it on also if their is a problem with the on off button.
if after doing the above you still cant get it on give me a shout back then ill assist you further ok
Dec 12, 2010 | Microsoft Xbox 360 Console
Attempting to instal router. orange symbol above
Follow the below steps to reset and reconfigure the router: RESET:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).  2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).  3. Power off the modem and the router after making the connections.  4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).  2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.  3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).   4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.  5. Click Apply.  6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
Hope this helps.
Jan 27, 2010 | NetGear WGR614 Wireless Router
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
Flashing orange arrow . cant get anything to print
Try taking out the print cartridges and then putting them back in and make sure they are really well inserted when you replace them. Then slam the lid down to really make sure its shut and it should resolve the problem.
Apr 02, 2009 | HP DeskJet 5150 InkJet Printer
Orange light is flashing
Unplug the power cord for 10 seconds
Feb 05, 2009 | HP LaserJet 1020 Printer
Mrs
The key means youre psp is locked, swith the power button to the middle (when its down, the psp is locked) if its not down, theres a problem with your power button and it needs to be replaced.
Feb 04, 2009 | Sony PlayStation Portable (PSP) Console
Connecting my cd stereo to 1990 Ford Taurus
since it worked before and you didnt change anything and now there is no power it looks like you blew a fuse when connecting wires. check the radio fuse on the door panel, and check the int. lighting fuse under the hood of the car. take both out and see if they are blown, if blown buy new fuses and replace.
heres the wiring diagram for a 1990 Ford Taurus:
Left Front (+) orange/lt green
Left Front (-) lt blue/white or Blk
Left Rear (+) pink/lt green
Left Rear (-) dk blue/ orange or Blk/Wht
Right Front (+) Wht/Lt green
Right Front (-) Dk green/ orange
Right Rear (+) pink/Lt blue
Right Rear (-) Tan/White
Lt green/yellow Hot at all times
Black - Ground
Yellow/Blk - Ignition
Lt blue/red - Acc
Orange/blk - Dimmer Lights
RED - Lights
Aug 22, 2008 | Car Audio & Video
Canon pixma mp150
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Feb 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
Gateway 450ROG Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
