MAYTAG WASHER; SMOKING BELTS; REPLACED BELTS; NOW TUB WON'T TURN.
    Brigadier General:
  • 3,917 Answers
Maytag Neptune front load washer won't drain water
maytag performance series washer front load drains very,very slow
Apr 07, 2012 | Maytag Washing Machines
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
My washer is not draining. I used to be able to reset it and it would work but now it wont start on any setting and is full of water. Is there anything i can try.
If your Maytag washer is not draining, follow these procedures to find out what is the problem.Set the timer in the spin cycle and pull the knob to turn the washer on. If the washer motor doesn't run, check the following parts.
The wall outlet: Make sure that there are about 120 volts present at the wall outlet. Connect a good working hair dryer to see if it works.If the hair dryer works ok, then the problem has to be in the washer. If the hair dryer doesn't work, then look for a blown fuse or tripped circuit breaker.
The lid or door switch : The lid switch is a safety device use to stop the motor from running if the washer door is opened during the agitation or spin cycles. A bad lid switch could be the reason for your washer not draining.
The pump : Check for obstructions inside of the pump and inside of the tub.
Check the pump impeller, the pump belt, check the drain hose for any kinks. Any problems in these parts could be the cause for the Maytag washer not draining.
Lower the drain hose to a bucket to see if the water drains out. If the water won’t drain or just trickles out, most likely there is an obstruction on the pump or inside of the tub and that could cause the washer not draining.
To check the pump, remove the front panel, lean the washer against the wall and bail the water out with a plastic container.
To check the pump, remove the pump belt and turn the pump pulley to make sure that the pulley is turning freely.
Put a couple towels near the pump to catch any water from the pump. Remove the tub to pump hose at and check inside of the pump for any obstruction. If you find an obstruction remove it.
If you don’t find anything, reinstall the hose and remove the hose at the tub, and check for obstructions.
A Maytag washer not draining could be cause simply by a kink drain hose.
You need to make sure that when you replace the pump, you adjust the belts properly.
Jan 29, 2010 | Maytag Washing Machines
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Maytag LAT3600A Top Load Washer
Amana LWD70AL is smoking, replaced the belt and still smoking and won't spin out.
is it a top load washer?Iwould cheak your pump to see if the bearing is tight just turn pully to see if it turns easy.If that does not work it may need a tub bearing kit and that would mean calling a repair man
May 07, 2009 | Whirlpool Inglis IP4400 Washer
Smoking washer
once you get the front panel off check the drain pump while your in there right now get a flashlight and look very closely at the holes in the tub for something like a nail or screwhead or something small enough to have slipped down in one of the holes of the inner tub and be jamming it now when you check the drin pump be warned there will be water still in the pump and tub so put down a bunch of towels
Mar 30, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire model CRWS5700AS0 washing machine burning belts
check the tub see if with the washer off.See if you can spin it both ways . let me know and i will advise futher this will be the spin tub
Jan 16, 2008 | Washing Machines
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
