Question about Sony Playstation 3 (PS3) Console
My disc is stuck in my ps3. when i turn on my system it flashes yellow then red 4 times but the disc will not come out and my system will not turn on
  • 4,102 Answers
Hi this is a very common problem and its to do with the ps3 over heating,
try the following.
leave it off and unplugged for an hour
check all air vents are free from fluff and dust and vac if needed.
make sure the ps3 is not being used whilst its on carpet
make sure the ps3 is not sitting on top of another electrical item such as dvd or sky box as this will cause it to over heat a lot quicker.
make sure its not wedged in a confined space it needs to have plenty of room around it to ensure cool air flow.
unplug all the leads from the back of the ps3 and the telly then plug them all back in, doing this removes any static that may have built up, then switch it on.
if after doing the above it still dont work then this indicates that either the gpu or cpu chip has over heated, if you have any warranty left take it back you need to check on the ps3 web site to see how old your ps3 is as this fault is covered by ps3 warranty for a couple of years but you need to check this.
now as for getting it repaired, well its a bit hit and miss i repair them myself and if it was an xbox 360 then i would say the chance of it working again is pretty high but as its a ps3 then these can be a bit hit and miss if the ps3 has over heated a lot and fried the cpu or gpu chip or both then the cost of repair would not be worth doing as it would be cheaper to buy a second hand ps3 or even a reconditioned one.
its not the kind of repair you can do yourself as you need to know how to test the circuit board to find out if the chips have been damaged.
the only other option you have is selling it for spares, i buy the damaged ones for spare parts but you wont get much for it as it is, i mean you could pay for the repair and you may get charged even though it cant be fixed,
i always say to my customers that if i cant repair it i will only charge for the parts i used which is nothing but if i do fix it then i charge them the cost of the repair, usually if its beyond repair they let me buy it off them as i pay more than they would get from ebay as they sell on their for about 30 quid with the problem you have got.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 17, 2010
I go to turn on my ps3 and the button turns green for a second then flashes yellow immediatly followed by the red button again but this time the red button is flashing and when you push it it stops...
You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED*
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
You will have to have the system repaired so that you can eject the disc the normal way. If the technician cannot repair your system, simply ask him to remove your disc.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
Turn it on amber light will flash then go straight to red light, then will not come on
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED*
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
Flashing red light , will not turn on , hand controller just flashing red lights , unable to remove disc.
IT CAN BE FIXED*
FOR THE DISC THAT IS STUCK INSIDE?
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
I was watching a film then my ps3 suddenly shut of with the red light constantly flashing, so i went to turn it back on and and then the yellow light came on and it shut back down with the red light...
IT CAN BE FIXED
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
My PS3 just shutdown while playing last night. The front light is red and turning on and off. When I try to restart the light turns into yellow and it continues to flash the red light
You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself. You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
The power on my ps3 does not stay on it powers on then cuts off immediately and the power light keeps blinking red and a bluray disc is stuck inside it will not release the disc
you have a yellow light of death if you look closely there is a yellow flash before it turns red the disc can be removed when its fixed as it needs to be serviced ok sorry to be bringer of bad news :(
Jan 13, 2011 | Sony Playstation 3 (PS3) Console
My ps3 shut off and I tried to turn it on again and it beeped 3 times, the power button went red,yellow and blue then shut down. After all that it still flashes red and does not turn on. I also have mw2...
Make sure that your PS3 is not put in an air tight space, direct sunlight, or heated room where it overheats. Put it in an open space, and make sure that there's sufficient air flow. Otherwise, You'll get the 'yellow light of death' Hope this helps.
Aug 24, 2010 | Sony Playstation 3 (PS3) Console
Disc stuck and then Ps3 system when turned on goes from green to yellow then blinking red
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
May 06, 2009 | Video Game Consoles & Games
Playstation 3 problem
Heat Sync issue. CPU and GPU need re-seating as well. Email dwdpcrepair@gmail.com for more help
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Sony Playstation 3 (PS3) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
