Question about Sharp LC32D47U 32 in. LCD TV
My sharp LCD TV is not turning on but flashing a green light twice and then a red light twice and repeats the pattern. I've already tried unplugging for a minute and even holding on the power button for a minute while unplugged, but without luck! Any other solutions??? Help please!!
5 Suggested Answers
  • 53 Answers
SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Posted on Mar 16, 2008
  • 33 Answers
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Posted on Dec 12, 2008
SOURCE: sharp 46 aquos model LC46E77UN tv turned off power
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Posted on Jun 04, 2010
diodeic
  • 1622 Answers
SOURCE: Sharp LC -46SB54U will not
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
Posted on Jun 16, 2011
DLP 65 in. wont turn on. Lights flash . Red light first followed by 9 green lights flashing-then shuts off.Repeats this pattern.My lamp is foggy but not blown. Is it the lamp? Lamp is 1 yr old.
While i don't recall that particular pro lemme alot of Toshiba sets had an issue with the ballast boars. Basically over time the solder connection s get hot and cool so much that the joints Crack and breal. The ballast board may need to be resoldered. If you choose to try this yourself...be advised there are very high voltages inside a tv that can seriously hurt or kill you.
Jul 07, 2016 | Toshiba Televison & Video
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
MY AKAI TV MODEL#LCT3701AD DOSNT WORK MENUELY AND REMOTE THE RED LIGHT IS COMMING BUT DOSNT TURN GREEN
Hi, when you turn on your tv does the red led flash in a pattern... does it flash a certain number of times quickly and then pause and
then repeat
If you can give information on this it will gretly assit us in diagnosing. Can you please check then add the details and repost the query.
If there is no pattern that may also help
Jul 03, 2015 | Akai LCT3701AD 37 in. LCD Television
Sharp LC -46SB54U will not turn on. The green power light flashes twice, then the green power light and green OPC light flash once together. This pattern then repeats itself over an over again. The tv is...
Do take care.....
Jun 16, 2011 | Sharp LC46SB54U 46 in. LCD TV
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Jun 04, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Red and green lights flashing intermittently when we turn it on.
take it back to place purchased /with receipt demand new one
Dec 24, 2017 | Sharp Aquos LC-19D45U 19 in. LCD TV
Sharp aquos red flashing light tv won't get picture
if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Sharp LC32D47U 32 in. LCD TV Logo
80 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
