It flashes f2 & all the lights keep flashing - Washing Machines
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Display F2 maschine will not start green light flashes two times then pauses
Normally this means the dishwasher is in flood mode. You would need to remove the lower base pan to gain access and check.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
I have a kenmore stove and it keeps flashing F2, I have unpluged it, could you please tell me what is wrong with it
is it e1 f2 or just f2. usually f2 means you have a shorted keyboard you need a new keypad.
May 28, 2009 | Kenmore Ovens
F2 flashing on screen of my GE Spectra oven.
Your oven temperature sensor has failed and must be replaced.
May 20, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Flashing F2 and beeping
Replace the oven temperature sensor.
Mar 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Jul 09, 2007 | Sony XM-752EQX Car Audio Amplifier
Washing Machines Logo
Top Washing Machines Experts
