Question about Whirlpool Washing Machines
When the washing machine is started it shows PE on the panel and nothing happens
  • 15,935 Answers
PE error.
Pressure sensor error. Cause: the sensor switch assembly is out of order.
Check the pressure switch -the system that determines correct water level in the drum.
If its giving an incorrect indication to the program timer machine will either overfill, refuse to fill or refuse to spin.
Its an air operated diaphragm switch triggered by rising air pressure induced by the entry of water into an airtight vessel attached to the base of the drum.
It tells the program timer that the water has reached the correct level, allowing it to proceed to the water heating stage in the cycle.
Power off.
drag machine out onto the floor.
remove back cover and top cover.
The pressure switch is a round item about 3 inches across with several wires and a thin rubber pipe attached.
It generally sits just under the top cover. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage.
Switch itself may be faulty but its more likely the pressure pipe or the vessel attached to the other end of the pipe is blocked.
Some machines have the pressure vessel integrated as part of the filter unit, with a pressure chamber moulded into the top of the filter body.
Remove the pressure vessel, put a small nut or screw in it, fill it with water and shake vigorously till any crud or residue is removed.
Refit all parts, check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at the foot of the machine.
Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine.
Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction.
Some hotpoint, indesit and ariston filters are located in the big black sump hose
(the one that leaves the bottom of the outer drum and connects to the pump).
Power off.
remove back cover or tip machine up at an angle.
Locate sump hose, remove the tensioner clip by squeezing the tabs together with a large pair of pliers or vise grips.
Remove the hose.
Take out filter and clean. Be prepared for spillage of water.
May help if the machine is tilted backwards at an angle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Testimonial: "Thanks for the immediate feedback"
I have an lg front loading an it showing pe signal
the PE error code is a power error code normally happens when there is a power failure you can turn the washer off then back on (not unplugging it) and this will clear the error code however if it happens with out any other reason then there maybe a power problem inside the diagnostic computer in the washing machine
Aug 05, 2016 | LG Washing Machines
Washing machine whirlpool topload showing pe
This question has been answered before here in Fixya. Check the link below if it answers your question. When the washing machine is started it shows PE on the panel and nothing...
Dec 08, 2014 | Washing Machines
Pe sensor error on lg washing machine
The best way to do is to call an LG service center regarding this problem.
Feb 01, 2014 | Washing Machines
My whitemagic machine allows me to select a program and when i press the start button it shows PE error. This is happening since 2 days now.
This is a Pressure Sensor Error.
Remove the top of the washer. The pressure is usually located at the top. It will have a plastic tube about 5/16 in size. Remove the tube and blow down into it to try and clear any blockage. If that doesn't work replace the pressure switch.
Oct 27, 2012 | Whirlpool Washing Machines
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Jun 19, 2011 | Washing Machines
Whenever i given its shows error peep sound ,its indicate error worrd -PE
Hello, LG Washing Machine Error Code "PE" -Pressure sensor error code -Check wiring connection to the pressure sensor. -Replace pressure sensor The sensor repair is simple and straight forward. If this helps please rate me thanks..
Jun 08, 2011 | Washing Machines
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
Washing Machines Logo
1,357 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
