Question about Acer Aspire 3935-6504 Notebook
Hi I need to remove the hard disk from my acer 3935, How can I do it, I see it located behind a plastic panel where a dvd drive would live. Is it just a case to remove the screws holding the back plate on?
  • 487 Answers
Hi, there is also a retaining scew holding the HD in place, then just gently slide the HD out from its conection pins.
Posted on Sep 16, 2010
Toshiba disk drive mk6028gal
The hard disk drive (HDD) in your Toshiba laptop is the component that holds all the files and folders you use.
If you are running out of room on the hard disk drive because of all the programs you have installed, it may be time to replace it with a new one that has a larger capacity.
Replacing the hard disk drive on a Toshiba laptop is a fairly straightforward and simple process, as you only need to remove one other component to be able to reach the hard drive.
Save a backup copy of any file or program that you will need from the original hard disk drive to an external device such as a CD-RW or USB flash drive.
Shut down the Toshiba laptop's operating system completely.
Disconnect the power cable if it was plugged in and then close the top screen lid.
Flip the entire unit over so that the bottom end of the laptop case is facing towards you.
Hold down the release latch for the Toshiba laptop's battery.
Slide the laptop battery out of the case and then put it aside.
Locate the screw at the upper-left corner of the case that holds the CD or DVD drive into place.
Remove the screw and set it aside. Grab the edge of the CD or DVD drive and then pull it away from the Toshiba laptop case. Set the drive aside.
Remove the four screws holding the large square plastic cover over the hard disk drive at the lower left end of the laptop case.
Lift the square plastic cover off the laptop case and set it aside so that you can see the metal plate that covers the hard disk drive.
Take out the screws holding the metal plate in place.
Lift the metal plate out of the case and set it aside.
Remove the two screws at the top edge of the hard disk drive and then the two screws at the bottom edge of the hard disk drive.
Disconnect the hard drive from the motherboard by sliding it out towards you.
Lift the hard disk drive out of the case and set it aside.
Push the new hard drive into the open slot and then reconnect the four screws.
Set the metal plate back on top of the new hard disk drive and then attach its screws.
Put the plastic cover on and reattach the cover's screws.
Slide the CD or DVD drive back into its port and then reconnect the screw.
Put the battery back into the Toshiba laptop.
Turn the laptop over and open up the screen.
Power the computer on. Insert the recovery disk that came with the Toshiba laptop into the CD or DVD drive.
Follow the operating system installation instructions that will appear on the screen.
Transfer the backup copies of the files you saved earlier from the external device to the new hard drive.
Toshiba Satellite hard drive replacement
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Aug 13, 2013 | Computers & Internet
Acer Aspire Am3470g case removal
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
May 04, 2012 | Acer Aspire Am3470g-uw10p
Where is the floppy disc on my acer SA80 - Z970
I doubt you have one. Computer manufacturers have not been installing floppy disks for some years now.
Jul 07, 2011 | Computers & Internet
Hard disk replace
remove the side panels to access your computers hard drive
put an earth ******** to earth yourself before proceeding
there are 4 screws 2 either side of the hrd drve
unplug the electrical lead followed by the IDE/SATA what ever applies
have a good look at the plastic jumper & the pin settings usually located at the rear of the hard drive next to IDE/SATA lead before removing anything
then place the new hard drive in rembering to look at the plastic jumper and its location
plug the electical & IDE/SATA lead in
restart your computer
hope this helps
Dec 09, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Acer Aspire 5100 will not boot
Two possible Solutions:
1) The Hard Drive has come unseated - Disconnect the Power and REMOVE all connections, Close the Screen & Turn your Laptop Upside Down and Remove the Battery, Locate the Hard Drive Access Panel and Remove the Screws from the Panel, Remove the Panel, Remove the Hard Drive. Carefully Replace the Hard Drive, Replace the Panel and Reconnect the Battery & Power Supply. See if the Computer will Start
2) The Operating System is Damaged OR the Hard Drive is Dead - You will need to slave Your Hard Dive into a Second Computer and Backup ALL you Personal Data OR RISK loosing it. If the Second Computer can NOT read the Drive, the Hard Drive is Dead (A Computer Repair Company may be Able to Help)
Once your Data is Safe, you can try to Repair the OS by Booting your Computer with the Drive in it. Begin pressing F12 or F10 at bootup (Once a Second). You will be presented with an Options Page for:
System Restore (FIX WINDOWS)
System Recovery (Wipes your Computer and Retores the Factory Software)
Hope this Helps!
Dec 22, 2009 | Acer Aspire5100 Notebook
How to remove hard drive from acer 1360 aspire
Detach the machine from the power supply.
Turn the Acer Aspire 1360 over. Remove the battery.
The hard disk caddy can be seen centrally located from the battery bay (it is shiny metal). There is a piece of clear plastic attached to the back end of the caddy.
This is usually pushed back on itself under the plastic casing.
There are two screws located in the casing around where the HDD is located.
One is deepset and one is much nearer the surface.
Remove the deepset screw and put aside for later.
Get hold of the clear plastic strip attached to the HDD caddy (you may need a small screw driver to 'fish' it out). Gently pull the HDD caddy into the battery bay. It should come out quite easily, but you do need to apply consistent and mild force.
Once you have the caddy out, you will notice that there are two screws holding the HDD in it. Remove them carefully.
Remove the HDD from the caddy.
Putting back together is the reverse of the above.
Jul 22, 2009 | Computers & Internet
How to take apart old, excellent running laptop for maintainence
When you have removed all the screws from the bottom of the laptop, and there may be screws in locations where the main battery, hard disk and CD/DVD drive was installed, Also there may be screws under the keyboard.
You need to remove the LCD screen (ie the hinges). You also may need to remove the plastic panel that houses the LED and push switches to get access to the video cable etc.
You should now be able to separate the case.
The two half of the laptop case are held together with plastic clips.The best way to separate the case is to start near a openning near the CD/DVD drive slot and gently prize the case apart until a clip catch releases and then work around the edges of the case in both directions until all the clips release.
I have found this method works best on various laptops.
Apr 11, 2009 | Acer Computers & Internet
I need help! I'm a computer novice so please excuse my ignorance. I recently bought an Acer Aspire M1100 desktop (Acer Aspire AM1100-B1410A Refurbished AMD Desktop PC - AMD Athlon X2 4000 2 .1GHz, 2GB...
here is what you will need to complete this project:
  • Your new DVD burner with the included screws and cable.
  • A phillips screwdriver.
  • your new harddrive
  • Once you unpack the drive and find a screwdriver, you can finish the prep work by turning off and unplugging the power from your PC.
Installing Your Harddrive Step1 Open up your case after backing up any important files and locating and installing any software that came with the hard drive. Check to make sure that your computer supports SATA or that you have a SATA PCI card installed. Step2Look for the smaller connector on the SATA cable and connect it to the SATA connector located on the motherboard or controller card. If you already have another SATA drive, simply follow its cable to the motherboard or card to see where this one will attach. Step3Grab the larger end of the SATA cable and connect it to the back of the SATA drive itself. You will also need to attach the legacy 4-pin connector or SATA power cable to power your drive. At this point, check to see that both the smaller and larger end of the SATA cable and the power cable are securely connected and proceed. Step4Choose an available drive bay and insert the hard drive into it, mounting it in place with the four screws provided. Make sure to follow the directions that came with your drive and place the screws in the designated holes to secure proper grounding. Step5Ensure that all cables are properly attached and replace the tower or desktop case cover. After doing this, you're all set to reconnect the power cord and turn on your computer. Formatting and Partitioning Step1Boot from your Windows CD. If this is the only hard drive present, you'll be shown a series of instructions and should simply follow along. Step2Select "Control Panel" then "Performance and Maintenance" and finally "Administrative Tools" for an additional hard drive. Then click the "Computer Management option and choose "Disk Management." Simply right-click the drive to partition and format it. Step3Follow the steps displayed. Windows will guide you through the rest of the process. Now for your dvd drive---- 1.Shut down the system, unplug the power cord and remove the side panel or panels from the case. Ensure that the new DVD-ROM drive is set to be "Slave" or "Master," depending on if it is a replacement or an additional drive. 3 2.Locate the empty drive bay for the new DVD-ROM drive, and remove the drive bay covering. 4 Insert the new DVD-ROM drive into the empty bay and secure with screws or other attaching device provided by the manufacturer. 5 3.Connect the open connector on the ribbon cable (red stripe towards power cable) to the new DVD-ROM drive and connect the power supply cable (plastic four connector plug from power supply)to the drive. 6 Replace the side panel or panels, plug in the power cord and turn the system on. Install your dvd software bundle and get to work. These are actually two things you will want to do at once while the computer is open , but i would do them one at a time in case you have problems you will know what to blame. You can leave the cover off while operating the computer so that you can test it after the hard drive instrall and before the dvd install.
Oct 21, 2008 | Acer Computers & Internet
Removing L100 hard drive
Remove the front panel by gently lifting the three flat plastic tabs. Remove one screw at the corner of the disk drive and lift the disk drive and DVD drive upward by the plastic handle on top. Disconnect the two SATA connectors from the disk drive by simply pulling them off. Disconnect the ribbon cable from the DVD drive gently lifting up on the black tab at the ribbon connector. This is hinged and releases the ribbon cable.
The unit is now free and you can turn it over and remove the screws securing the disk drive.
Jul 20, 2008 | Acer Aspire L100 PC Desktop
Cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Jun 04, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 3935-6504 Notebook Logo
244 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
