Question about Indesit 24 in. IDL500 Built-In Dishwasher
My dishwasher is leaking from front bottom left side when on. have checked the door seal and it is worn about 3" up on left. there is also a rubber seal on the door itself running along the bottom. can this also be replaced and if so where can i get one?
  • Indesit Master
  • 43,501 Answers
Hi, Yes, they can both be replaced...this tip will also tell you how to purchase them...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 16, 2010
We are having water leak from the bottom of our Roper Dishwasher door. THe model # is RUD5750DG3. I have taken the inside door frame off and found a small white rubber seal had dislodged inside. i...
Step 1:
Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
Step 2:
Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
Step 3:
Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
Step 4:
221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine Step 1:
Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
Step 2:
Open the door completely and remove the bottom dish rack.
Step 3:
Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
Step 4:
Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
Step 5:
Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
Step 6:
Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door Step 1:
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step 2:
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step 3:
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step 4:
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step 5:
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Apr 06, 2008 | Dishwashers
My black LG 24 builtin dishwasher has suddenly started leaking about 1/3 cup of water around the bottom vent on the door (LH side). How do I make adjustments to the door to stop this? I have already...
Check the door seal. To do this, make sure the door and the rubber gasket is complete dry. Apply a liberal amount of liquid detergent around the rubber gasket. Then close the door. Open the door and look for the liquid detergent to transfer onto the door. If there is a gap, then you will need to replace the door seal.
Jun 17, 2011 | LG Dishwashers
We have water leaking out of the left side of the dishwasher occasionally. About 1 in 3 loads will leak. Most of the time it is a small leak 1/4 cup or less but once it was a spray out.
One (or possibly both) of your door seals needsreplacing. It's more likely to be the lower door seal as these usually go first. This seal isn't visible like the goalpost seal that runs around the sides and top of the wash compartment. If you open the door, you can feel this rubber seal when you run your fingers along the bottom of the door on the inside. Be careful though, as there is often a build up of dirt down there!
I don't advise buying any parts until you are certain of where the leak is coming from. Identifying the source of the leak (and therefore which seal to replace) is relatively easy but the best way is to run a wash cycle with the front panel of the door removed. It's quite easy to remove, but you might need a T20 T-Star screwdriver to remove it. Sorry, I can't remember exactly what the fixings are on this model.
A simpler - but not always accurate method - is to check by look and feel. If the water seems to be coming from the sides of the door panel at the bottom when you run a wash cycle, it's the "goalpost" seal that needs replacing. These are easy to obtain and replace - they simply push into a slot.
To test the bottom door seal, run any wash cycle and, when it's finished, stand to the side of the washer and open the door. There is a white plastic panel under the door. Have a feel around on top of this. If it's wet you probably need a new lower door seal. These are much harder to replace as it involves removing the door panel and partially releasing the hinges. I don't recommend this as a DIY fix unless you are competent, confident and have good instructions - i.e a service manual!
Whichever seal you need, they cost around $30 / £20 each.
Please rate this solution if you find it helpful. Thanks.
Oct 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Westinghouse 906 leaks from front door
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Leaking problem from the door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
May 03, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
Frigidaire Dishwasher Leaking
I just found a service release number for my Frigidaire dishwasher that says it applies to Serial numbers TH632 through serial number TH737 made in 2007 for a replacement kit for the door seal at the bottom of the door. The bottom door seal has been changed, adding side seals that restrict the water surge from the center spray arm. The part number for the new seal is p/n 154588201. This seal can be replaced without removing the dishwasher or either of the door panels.
The seal is located on the bottom of the inner door panel and appears as a cream colored flexible
rubber blade bonded to a milky white colored plastic strip. To remove and properly install
replacement follow the instructions carefully.
1. Replacing this seal can be accomplished without disconnecting power from the unit.
Always use extra care when electrical power is present while serving an appliance.
2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the
seal can be pulled down slightly to facilitate removal.
4. Pull seal straight into the tub from right side.
5. With seal removed, and before installing replacement seal, locate the channel in inner door
panel that the seal mounts into. Locating this channel before installing the replacement can
make this procedure easier.
SERVICE FLASH
DW071
6. Place the new seal on a flat surface and measure from the bottom of the seal, (See Figure
1 to determine bottom of seal), up 3/8 "of an inch and place a mark with a pen or marker on
both ends (See Figure 2). If needed, scribe a straight line between these two marks this
will give you a guide when installing seal into the inner door panel.
7. The seal can only be installed one way. The end that holds this seal into the inner door
panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed
around the end of the inner door channel that holds the seal.
8. Line up the seal along the bottom of the inner door panel and start from the right side, push
the seal into the door channel to the line marked in step #6.
9. With seal in place close the door, the tub will align the seal as needed.
10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit 154701001 for
dishwasher.
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make
sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on
both ends. This locates how far down the seal needs to be before closing the door. Do not
install this seal without measuring it first. After the lower door seal has been re-installed then
install the splash shields according to the instructions accompanying with the kit.
Sep 18, 2007 | Dishwashers
Indesit 24 in. IDL500 Built-In Dishwasher Logo
324 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
