Question about Samsung WF337AA Front Load Washer
No water flowing into drum, water supply is fine, just humms
My Samsung washer was not filling with water after cleaning the debris filter. All I did to fix it was to dump a half gallon of water into the tumbler, then I ran the beginning of the rinse cycle and it worked. It seems like the pump needed to be primed.
Posted on Aug 04, 2011
  • Samsung Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 16, 2010
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Danby wont start only hums
Sounds like it make be the belt is broke, without this the wheel is unable to turn the drum.
failing that it may be a sinister motor problem needing a rewind of motor which usually is not worth it...
best of luck either way
Apr 15, 2014 | Danby DWM5500 Front Load Washer
When i try to start it just humms all lights in start up panel light up except last one that says control
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.
Jul 03, 2012 | Whirlpool Washing Machines
Water fm the cold side have very low flow. have check the hose for clog..clear. check the supply. strong. when the sector switch in the hot or hot/cold water flows but on cold low flow. unit is...
You need to replace the water inlet valve. Since you confirmed that the hot water side works fine, the cold water side is not allow a good water flow. It is a relatively easy repair. The part can be obtained a any local appliance supply house or online. To repair, disconnect the supply hoses to the machine, remove the back panel and the part is behind the panel. Hope this helps you.
Nov 08, 2010 | Whirlpool Washing Machines
I have a frigidaire dryer. The motor humms but the drum does not turn. The belt is not off the drum.
a humming (shaking) motor means the coils have lost there magnetic feild (replace the motor) and it will work fine
please remember to rank this post
thanks
Jun 21, 2010 | Dryers
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water authority turned off water & washer not working now
Disturbing the water supply caused sediment to flow in and block the inlet screen(s) on your washer. Take the supply hoses off and look inside the part they screwed off of to find screens. Remove the screens and clean. Reinstall. Check that there are not filter style hose washers in either end of the supply hoses which may need to be cleaned out.
Jan 06, 2009 | GE Energy Star WCVH6260F Front Load Washer
I have a lg wm2277hw agitator problem
I had this happen on mine, and it was the valve that dispenses the water into the drum. I wasn't getting any water into the drum because the dispensing valve/solenoid was not working. I've had to replace it 3 times in the past 5 years though.
Dec 02, 2008 | LG WM-2277HW Front Load Washer
Hot washes won't start
check the hot water supply is switched on- it sounds like the valve is energising but no water is gettin through !! also check for hot water blockages. easy test is to reverse the water pipes at the back of the machine to test. tony.
Aug 07, 2006 | Hotpoint Aquarius WD63 Front Load...
Samsung WF337AA Front Load Washer Logo
1,122 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
