Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Any cycles using cold water won't run - Maytag Ensignia 3.3 cu. ft. Top Load Washer
  • Maytag Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 16, 2010
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Oct 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
    59 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
