Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Water continues to run because water is draining at same time. So, the water level doesnt rise
  • Frigidaire Master
  • 43,501 Answers
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Sep 16, 2010
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
When filling the drum the water drains out with switch not in drain position. and drain pump not running?
Rise you drain tube/hose from the floor. Where the drain hise goes out of the machine, rise it up to the height of the machine. Then connect it to the drain pipes
Feb 17, 2016 | Washing Machines
Indesit iwb5113 keeps filling up
The water level in your, and most other, washing and dishwashing machines is controlled by an air pressure switch that senses water level by the rising air pressure compressed in the pressure, (level), switch body itself. This air pressure is usually transmitted by a thin rubber tube on the bottom of the washing machine drum, or sump hose. As the water gets higher in the drum, air is compressed in the level switch until it operates, and turns the fill valves off. The pressure switch is always mounted at the top of the washing machine cabinet - look for a circular switch with the thin rubber or plastic tube fitted into the bottom. What can happen is if the rubber tube rubs against moving parts in the washer, it can get a hole worn in it - so the air does not compress and the water doesn't turn off.. You will have to examine the tube very carefully to find holes like this. Alternatively, the tube could have come off, or blocked with limescale at the bottom end - try removing the tube at the pressure switch end and blowing through it - any blockage must be removed. A last, rare, possibility is the rubber diaphragm in the pressure switch is leaking - but very very rare. Most modern machines have an electronic backup that measures fill time in case the pressure switch fails. If your machine floods, it doesn't have this.
Jan 19, 2018 | Washing Machines
Our Saniflow motor unit has started to continue to run some times after the pump has operated. This has to be stopped either by switching off power for a while or sometimes leaving the tap on to cause the...
Sounds like the level switch has debris stuck under it preventing it from switching off - disconnect the power and remove the lid. The level switch is the oval shped object next to the motor, there is a diaphragm on its underside which rises under the influence of rising water level, tripping a microswitch to start the pump. Check for free space under the diaphragm or stiffnes of the diaphragm reducing its moveability - this stiffnes or hardening of the diaphragm is often caused by abnormal liquids being poured down the drain such as paint thinners etc.
Jan 20, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Water keeps running into machine when it is done but not into the tub but no water leaking on floor so must be going right out of the drain
water can't run out of drain until the drain pump runs. must be water level continuously rising, but slowly. definitely water solenoid switch problem. pl. open and clean if u can or replace.
Oct 28, 2009 | Maytag Washing Machines
The toilet has water running continuously from the tank but not to the stool
bad shut off float pull the float up manually does that shut it off if so adjust float to go off at a lower water level. If it doesnt replace it. The float is attached to a water shut off valve as it rises to a certain point which you set, when it reaches that water level it shuts off the water.
Oct 18, 2009 | Pegasus Technologies Elongated 2 Piece...
Water continuously runs and cycle won't start. The washer tub doesn't seem to be filling with any water.
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
Aug 08, 2009 | GE WVSR1060A Top Load Washer
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
We purchased a Whirlpool portable air conditioner in 2005 from Best Buy. Near the end of last summer the air conditioner started leaking water. We started using it again this season and it is still...
Check to see if the drain is blocked by particles/debris of any type. Also make sure that the unit is level--as level as possible. I have my Whirlpool Portable AC in 4 inch bed risers so I can drain it really easily. I slip under a small low rise pan and drain it every two days or so when it is running. Mine leaked when I tried to incline it backwards to make it drain faster. As soon as I leveled the unit the leak stopped and water again came out the hose. These units must be kept level to prevent leaks so now I always do that.
Jun 09, 2008 | Whirlpool Heating & Cooling
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
