I have a 60 GB archos av 500 and recently its stoped workin with no previous problems its just not turning on not wen i connect the power cable or anything just black no lights and no screen please help
  • 35 Answers
Hi sion1992,this seem to be power supply problem.rectify with a qualified technician in ur area.
raj..
Posted on May 17, 2008
I HAVE A ARCHOS AV 500 I WAS WONDRING IF THERE IS ANYWAY TO CONNECT IT TO THE TV SO I CAN WATCH THE ARCHOS VIDEOS ON MY TV THANKS
You can use a disc shaped connector hub for AV in/out connections, but no travel AV in/out. That is a separate accessory. So, if you want to see your video on a separate TV, bring the big hub, or spring for a separate set of travel connectors.
Thanks
Oct 13, 2009 | Archos AV 500 Digital Media Player
Archos AV500 / USB harddive
from what i gathered with my archos 5 it is due to a power issue so the archos does not provide enough power to make the external hd work
Mar 08, 2009 | Archos 605 WiFi Digital Media Player
WD 500 GB Hard Drive just stoped working, It has the alternating blue lights in front, now as soon as it powers up it turns off - the alternation blue light don't even come on I still had 316 GB left on...
I had the same exact problem for a while and I think it's a problem with the slot where the USB cable connects to the HDD. I eventually just took a small knife and pushed in the metal tabs around where the cable connects as they were pushed out from the cable being pulled at random angles before. Somehow it works perfectly now, so I guess it just wasn't detecting a computer or in this case an xbox and automatically powering down to save electricity and heat. Anyway I just thought I'd share my experience, good luck with your HD!
Dec 14, 2008 | Computers & Internet
Charging problems
I've got the same problem. The only solution I have come up with is to purchase an external battery charger.
Mar 10, 2008 | Archos AV 500 Digital Media Player
Sound problem
Make sure that the sound cables are connected,If you are using the RED BLUE GREEN cables,they do not carry sound.You have to run a set of sound cables RED AND WHITE to the Archos from the cable BOX or whichever component you are recording from.Good Luck.
Dec 29, 2007 | Archos AV 700 160-Hours Video Recorder
AV 500 "No input signal" on multiple attempts
Check to make sure all of the configuration on the AV 500 are as they should be. If they are you are looking at a defective unit (might be hardware based) if it is I would suggest that is you do not have a background in electronics to take the unit to a repair shop. If you do have experience you will need the following items: A schematic diagram of the AV 500 A Multimeter to measure the voltages at test points of the AV 500 An Oscilloscope to measure the signals and levels at test points of the AV 500 if you have these pieces of equipment then you will want to start your test at the dectector stage (this is where video and audio are separated from the IF which is derivied from the RF so if you have video and audio at this point you know the input RF-IF-detector stages are working. Now based on your troubleshooting you inputted signal at the video processor by using the the video inputs, so from this I am going to take a stab at saying the problem more then likely would be located in the stages at and after the video processor stage (since in this case no signal may mean no video signal as opposed to no RF signal).
Sep 06, 2007 | Archos AV 500 400-Hours Video Recorder
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
Archos AV504 problem
you cannot change any thing on the AV,500GH the mechanism are built in to work on operating system 1.5.12.
Jan 12, 2007 | Archos AV 500 400-Hours Video Recorder
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
