Question about Speed Queen AWS75NW Top Load Washer
I need to connect my washing machine. It has two pipes to full in water cold and hot but i will only be using the cold water and if i connect the one pipe, the water drains from the hot water pipe what do I do as i only have one connection to the cold water tap only.
  • 176 Answers
No problem can you using cold water only
Posted on Sep 16, 2010
DOES MY WIXL143S INDESIT USE HOT OR COLD MAINS
That's easy to tell- if it has 2 inlet pipe/hose connections at the back (as opposed to the outlet pipe which is permanently connected to the washer and hooks over the outlet drain) then it is a hot and cold fill. If there is only one inlet pipe it is cold fill only. Either type HAS to have a cold fill supply- to lower the temperature of the hot water for cool washes AND for rinsing which is normally cold water only.
If you have only a cold water tap/fawcet available for the washer and it is a hot and cold fill you will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Hope this has clarified!
John C
Oct 29, 2011 | Indesit W 123 Front Load Washer
I have been delivered a Aquiras Extra WMA 40 but I only have a cold pipe but I notice the machine has a hot and cold pipes do I connect to just the cold pipe and will the machine heat the water inside
No, the machine does not have a heater unless it has a sanitizing cycle which heats already hot water even hotter.
For the machine to work as advertised, you'll need hot and cold water connections. However, if you just hookup the cold water and run the machine on its cold-water setting it will wash -- the laundry may not be as clean as you would like in some cases, but the machine will operate properly.
Charlie
Jan 06, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Regards,
BElectric
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
GOT GERMAN INSTRUCTION BOOK AND OPERATING GUIDE NEED ENGLISH ONE. PLUS ONLY ONE WATER PIPE DO I NEED A CONNECTOR PIPE TO CONNECT HOT AND COLD WATER PIPES INTO ONE OR DOES THE MACHINE HEAT THE WATER UP ITS...
for the instruction manual... you can "googe" search online for it...type your brand name in the search window with "support" and you'll most likely find the factory website with manual downloads.
For the water issue: most washers are designed to connect to a hot and cold water supply. If yours is a one water pipe connection, and you're ok with cold water washes, I'd recommend supplying water to both the hot and cold connections of the washer, so you don't have any mishaps by hitting the wrong wash cycle and not getting any water. You could purchase a simple hose bib splitter fo accomplish this.
If however, you want hot water, sounds like a plumbing job to bring hot water to the washer's location.
It won't hurt the machine to run cold water to both sides...you just won't get the hot water cleaning benefit.
Jun 29, 2009 | Whirlpool Washing Machines
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
Washing machine
This is a Hot and Cold fill m/c.
You obviously have the hot water supply connected to the cold in let valve..
at the rear they are marked H and C .
Make sure the cold water is connected to C,and the hot to H.
Plz rate my solution. Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Speed Queen AWS75NW Top Load Washer Logo
75 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Charles T Nevin
Charles T Nevin
fta777
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
