Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Hi, I am using Konica Minolta bizhub C300. I can't use printing duplex. I am working on Mac 10.6.4. system. Is there any possibility to use the duplex function Best Ania
    Brigadier General:
  • 3,917 Answers
Hi
To set duplex printing, follow the below instructions:
1. Select 'Properties' from the Print dialog.
Note: Properties may be indicated as Advanced, depending on the application software.
2. Click the Page Setup tab.
3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'.
4. Select 'Duplex Printing'.
When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed.
5. Specify Staple Side. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position.Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. If necessary, click Specify Margin... and set the Margin width.
6. When the setting is completed, click the OK button at the bottom of the window.
If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
If Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages.
7. You will be prompted, while printing, to remove the printed page and reload it in the ASF.
8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed.
Please accept the solution if it's helpful. Do get back to us for any further query.
Posted on Sep 16, 2010
Konica minolta bizhub c300
Check the scanner lamp. It is possible the scanner is faulty. Try to replace with a known working lamp. If this doesn't work you might have to check the scanner board or the CCD lense.
Jul 09, 2013 | Office Equipment & Supplies
Printer status report printing on each print in konica minolta bizhub c300
Printer status report, you can turn this off simply go to Printer properties check there.Check in printing preferences option.Also check in your Microsoft Office setting.Printer report printing is turned on simply turn it off.
Jan 10, 2012 | Konica Minolta Bizhub C300 All-In-One...
How to configure bizhub c300
can you check the protocal settings in printer properties
Dec 28, 2011 | Konica Minolta Bizhub C300 All-In-One...
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Bixhub c351- I can copy in duplex but i can not print in duplex
Have you told the print driver that you have a duplex fitted, also is the paper set as plain as any thick setting will cancel out the duplex function.
Jun 16, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jun 01, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Printer Busy message
check your mac connection settings, change if needed, try install new printer.
Dec 07, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
350 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
