Question about Hotpoint HTR15ABMLAA / HTR15ABMLWW Top Freezer Refrigerator
Part numbers for a hotpoint htr-15 abmblww refrigerator the vegetable drawer cover
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
SOURCE: Leaking Whirlpool refrigerator
I had a problem with water accumulating on the first shelf and and underneath the drawers in the bottom of the refrigerator. I traced it back to the overflow cup that is located inside the refrigerator in the middle of the top. NOT inside the freezer, but rather in the the refrigerator portion.
Unload the top shelf and place some paper towels near the back of the shelf to catch about a 1/2 cup of water. Gently grab the tab on the overflow cup and slide it towards you. I am willing to bet there is a large plug of mold inside the pipe on the cup that has been blocking the drainage.
Now is a good time to clean up the water under the drawers in the bottom of the fridge and while you are at it, clean the shelves.
Posted on Jun 01, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    SOURCE: Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
    Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
    Posted on Apr 14, 2009
    • 532 Answers
    SOURCE: Freezer door pops open when refrigerator door is closed and water is gathering under vegetable drawers.
    Well the water gathering is probably the drain hole plugged,(under bottom drawer),its a round plug that sticks up a little,it turns out like a bolt,--now about the freezer door,how is the door seal?bad as in warped,torn,bent?incase you didnt know there is a magnet inside the seal.also check if the door needs to be re-adjusted
    Posted on Apr 21, 2009
    Water build up
    Good Afternoon Friend,
    I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
    -Best Regards-
    WP
    May 29, 2014 | Frigidaire Refrigerators
    Water leaking inside the vegetable drawer
    What is your model number? Also what year, series etc.
    Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
    My Hotpoint refrigerator has a full bottom drawer and the vegetables freeze. Can you tell me what to do?
    Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
    Refrigeratoris Too Cold and Freezing Food
    heatman101
    Apr 30, 2011 | Hotpoint Refrigerators
    Vegetables freezing in crisper drawer
    This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
    Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
    Bosch Refrigerator ice forming in vegetable drawer
    Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
    Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
    Vegetable draw is freezing the vegetables
    if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
    Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
    GE side-by-side Refrigerator too cold, runs all the time
    If the problem is in the vegetable crisper drawer primarily, Google "WR49X10045". This is a simple fix kit for a design flaw.
    Nov 28, 2007 | Refrigerators
    Hotpoint HTR15ABMLAA / HTR15ABMLWW Top Freezer Refrigerator Logo
    61 people viewed this question
    Top Hotpoint Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Sal DeAngelo
    Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
