Question about Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour
HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
    Habit-Forming:
  • 95 Answers
I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
Posted on Oct 07, 2014
Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Feb 22, 2011 | Vacuums
I have power and water to the fountain, but fail to get the water to pump to the fountain head
The water pressure get the water to the spout it is not pumped there. You have a valve in the off position some where. http://www.elkayusa.com/cps/rde/xbcr/elkay/12-23D_EZ_EZS_EZSD_EZD.pdf this link shows an electric solenoid valve and also a manual valve.
Feb 18, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
Ice maker waterwont tureoff
You either have the=> 4389177 Dual Water Control Valves have gone bad on the dispenser side and remaining open or a defective dispenser switch in fountain. Click Here=> Item 14 KSRD22FKST15 Fountain Parts I don't think the keyboard is the problem in this case. If the water control stays open very long it has been known to damage the solenoid on the water control valve. If you have other questions please let me know, Thanks Sea Breeze
2162361 Micro Switch Click Photo
Jan 16, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Water has stopped flowing to the ice maker but is ok to the door fountain. hoses appear to be ok.
sounds like you ice maker is shut off. There should be a switch next to ice maker to turn back on. Also look for a lock out feature for the ice maker. It could also be a sticking water solenoid to allow water to enter tray.
Dec 04, 2010 | Kenmore 57029 Side by Side Refrigerator
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
May 04, 2009 | Jenn-Air JCD2295HES Side by Side...
No water is going onto the ice maker (Maytag Model # MZD2766gew)
the water solenoid valve is normally triggered by the ice maker itself. as it turn to harvest the ice, it should trigger the water solenoid valve to start another cycle of ice making. its either a wire harness problem that's why power is not getting to the valve or the triggering switch of the ice maker not sending power to the solenoid. i hope i was able to help you guys...
Jan 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour Logo
913 people viewed this question
Top Elkay Plumbing Experts
jdthefixer
rdjagger
Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
