Question about Ironman 220t Programmable Treadmill (225 HP)
Treadmill stops-code E11 shows on screen also, where may i find a manual for this model? thank you for your assistance
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
ercupa190
  • 12223 Answers
SOURCE: I have an IRONMAN 220T treadmill and have a code # E11 and I do not know what it mean, can anyone help me with this.
E11 Means that deck bel or walk belt is slower speed that speed window .
2 possible causes:a) Locked rotor from main motor b) High friction from deck or walk belt.
3) Use the calibration software from your equipment for easy diagnostic and correction.
4)Use the owner manual or your step under the Hood ,and proceed with the steps indicated.
5) You can lubricate the Deck or Walk belt. please see your owner manual section: Maintenance.http://www.youtube.com/watch?v=f7IZWMMrCM0 please see this videos for easy help in lubricating. and adjusting deck belt treadmill.
http://www.youtube.com/watch?v=AZSMLpXm-tA
sincerely. Merry Chrstmas.
ernesto cuadramanagua, nicaragua.c.a.
Posted on Dec 24, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
Twice my new kenmore microwave has just started beeping with the error code E11 appearing on the screen.Have to unplug it to stop it. WHat is going on?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter
Aug 07, 2014 | Kenmore Microwave Ovens
What is E11 code?
Hello Friend, this is Z. Thank you for your post!
If you are receiving an error code E11, please check the following:
    ·Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your washing machine. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
    ·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
    ·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
    Hope this helps!
Jul 26, 2014 | Frigidaire ATF6000ES Front Load Washer
Error code e11
hi
1.Check that the LED light flashes on the motor controller while rotating the flywheel, check the connections on the controller and control panel.
Feb 18, 2014 | Ironman Envision Treadmill Drive Motor
E11 error code
Good Morning Juan, thank you for allowing me to assist you!
Generally, error code E11 indicates that your washing machine is taking a long time to fill (or is continuing to fill).
    ·Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from your washing machine. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
Jan 16, 2014 | Frigidaire ATF6000ES Front Load Washer
E11 problem
Good Morning Mohamed, thank you for allowing me to assist you!
Generally, error code E11 means that your washing machine is taking a long time to fill (or is continuing to fill).
Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your appliance. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Dec 08, 2013 | Frigidaire Affinity ATF7000E Front Load...
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
Dec 22, 2011 | Ironman 220t Programmable Treadmill (225...
When I turn the Keys Fitness Elite treadmill on, after 12 seconds, it shuts off and code E11 appears. I read the tech support page on their web site and perform the calibration sequence. Once I got to the...
Do not forget to accept the solution, if 100% satisfied from my solution!!
The walking belt is moving slower that the console is showing. Many times, the same symptoms can cause an E11 and an E22 error.
  1. The most common problem is belt/deck friction. If you have a belt that has too much friction, it can cause a wide enough speed variation to create an error. You can try our World Famous lube to help but eventually at least the belt will have to be replaced.
  2. Before doing anything, check the drive system for a foreign object. A little “helper” can put a small ball in the drive system and you'll get an error code.
  3. Be aware of any noises the treadmill was making. If the treadmill had a screeching noise, the bearings in one of the bearings or motor could have had a problem. Read our help section on how to find bearing noise to isolate which part is causing the trouble.
  4. Make sure the motor fan is firmly attached to the motor shaft. There are a series of “fins” on the fan that are read by the speed sensor. If it is not properly attached, you can get a bad reading. Also if some of the fins have broken off, a bad reading results.
Check the wire from the speed sensor and make sure it is firmly in place on the sensor and the electronics. Make sure the S F/B LED on the controller flashes as the fan turns. This is telling you the sensor is reading properly. Clean the sensor with a Q-tip and rubbing alcohol if it doesn't flash and if that doesn't fix it, replace the sensor.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 10, 2009 | Keys Fitness Exercise & Fitness
Ironman 220t Programmable Treadmill (225 HP) Logo
136 people viewed this question
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Jim Dowell
Techmotionusa.com
Techmotionusa.com
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
