Question about Microwave Ovens
How to use Simpson Evolution 805 Oven? - Microwave Ovens
I am getting code F3 on my ge evolution and the oven will not work. what does F3 code mean?
That is a shorting membrane keypad.
To help you with free DIY or other info, we would need your full model number as shown on the tag in the cooking cavity or elsewhere on the oven.
The FCC ID number from the same tag might be helpful for diagnosis, too.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 08, 2017 | GE Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I bought a KitchenAid 24" microwave oven and trim kit.to replace an old KitchenAid 24" oven. The old oven set on the built-in shelf with a stainless steel trim panel around the oven to trim the cut-out. ...
As long as there is ventilation at the back and somewhere for the air to come out go ahead and use you imagination to make the trim kit look good to the eye. Making those tough decisions is what installers do.
Oct 17, 2013 | KitchenAid Microwave Ovens
Error message of "F3" appears
F3 or F4
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Keep us updated.
Jul 10, 2011 | Hotpoint RVM1325WW Microwave Oven
I purchases the Nostalgia Electric Cotton Candy Maker Model # PCM-805 yesterday at Bed Bath & Beyond. The directions, scoop and 2 plastic cones were missing. Can these be sent to me? (The store...
I would call customer service at Bed Bath & Beyond and ask for replacement parts. You might have to bring in your receipt. They should have no problem replacing the missing items, and if Bed Bath & Beyond doesn't have the items, they could most likely call the company for you.
Dec 07, 2010 | Microwave Ovens
I have lost the grinder knife for my kitchenetics Gourmet champ grinder.Where can I get a replacement
Hi, The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
Phone
Toll Free: 800-253-6383
Local: 801-222-0888
Fax: 801-805-8585
Jul 27, 2010 | Microwave Ovens
Hi, my microwave is not heating and i cannot hear any humming sounds either. I replace a new magnetron already and it's the same. What else could it be? do you think I should replace the capacitor, diode...
I would have started with the diode and capacitor (i.e the least expense) but you can check the diode by removing the input wire and doing a continuity check in BOTH directions. In other words check it then reverse the leads and check it again. It should only read in ONE direction. If it reads continuity in both directions or is open in both directions it is bad and must be replaced. If the diode check out fine then by all means check the capacitor. Just respect the fact it is a large capacitor and can really ruin your day if it is good and has a full charge. (Been there done that!) Take a screwdriver and ground across the terminals several times then note the position of the wires on the capacitor and remove the wires from ONE terminal set. Take your meter still on Ohms ( old simpson type dial meter for this test) and place it on the capacitors 2 terminals. Then rapidly reverse the leads and you should see a momentary jump on the meter then fall off. No jump when you repeatedly reverse the leads then the capacitor is bad. This should solve your problem unless there is a relay on the control board that controls the magnetron power.
Jan 16, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Sharp R-1500 range lights
Are any other bulbs in the home going out prematurely? If so, I would check the actual voltage of your power outlets. If not, the bulbs may be getting grease or debris on them from stovetop cooking. This can cause hot psots and premature failure. I recommend wiping them clean with alcohol on a cloth before installing them. I recommend that folks always have their hood fan on when cooking on the stovetop. Also, you might check with a local home center (Lowe's, Home Depot, etc.) to see if they have some high-quality (non-Chinese) substitutes.
Aug 08, 2007 | Sharp R-1500 Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
