Question about Maytag Neptune MDG5500AW Gas Dryer
Air blows but does not get hot what part is broken
  • 176 Answers
Some thentk is ronge
mebe fuses mebe heater
Posted on Sep 16, 2010
Heater blows hot on passenger side of car but blows cold air on drivers side in a 2000 grand prix
Look for a loose to broken air hose for the drivers side damper motor.
Nov 17, 2014 | Cars & Trucks
Car wont blow hot air heater
all cars... (otto cycle petrol /gasoline)
hot Air comes from hot water , in the engine,
so the first check is that the coolant does hit 180F and hold.
if not the thermostat in the engine is toast.
ok 180F , hot motor.
next ,some cars have a water valve for the heater coil
(alldata dot com, read the manual)
if the valve or its dash control to it is broken then it sticks closed.
other cars have no valve and they only block the core (bypass) the air to make hot and cold.
that too is a control. there are 3 types used, cable, vacuum and electric. on all cars.
what you have , is based on YEAR and options.
the book shows how to fix this. me ,just look at the controls.
if there is a cable then I make sure the cable works.
The heater has what are called damper, (flaps)
they open or close.
and if you have A/C more.
if the engines is hot. my guess, is the bypass damper is stuck
in the bypass mode. (fresh air only)
the best way to work on any car is RTM
you do that because these parts vary radically by year. and make.
alldata dot com is the solution , under HVAC.
Oct 07, 2013 | Pontiac G5 Cars & Trucks
Air blows hot air all the time
If the actuator is moving when you move the control it may be a broken or warped plastic door. If the actuator does not move look for a bad control unit or a vacuum leak.
Mar 05, 2012 | Mercury Grand Marquis Cars & Trucks
My heater stoped blowing hot air.antifreeze level
If the blower is blowing air just fine, but you cannot control the temperature, you need to listen to air coming from the vents while turning the temperature from hot to cold. If you do n ot hear any change in airflow, then you may a temperature door in the dash broken. this is becoming a common problem on the Equinox and Pontiac Torrent,
Tech JK
Oct 13, 2009 | 2006 Chevrolet Equinox
Ac blowing hot air
the blend door actuator located on the air box (right hand side under dash) is prob. inop. worst case senerio the blend door its self is broken. I have replaced the actuator more than anything.
Sep 16, 2009 | 2005 Chevrolet Silverado
98 navi blows hot air from front vents and cold air in the rear.
red or white vac line disconected or broken in engien bay
Jun 09, 2009 | 2003 Lincoln Navigator
Temperature Control not working on 1999 Ford Explorer
Sounds like your temperature actuator is not moving or your temp door is broken. On max a-c ,coolant is shut off to your heater core allowing only cold air in.
Jan 16, 2009 | 1999 Ford Explorer
AC blows hot
I think you should check the air manifold on the control panel and try to find any broken or loose hose.
In addition, check the heat/cold dial knob, under the dash, there is a panel selector for hot air or cold air.
Also check for any broken vacuum hose under the hood.
Jun 07, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Maytag Neptune MDG5500AW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
