Canon LASER SHOT LBP 3300 Printer Logo
Posted on Sep 16, 2010
I'm using CANON LBP 3300 Printer...When I load Legal paper in Cassette , it's asking to load in manual slot.. Please help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
991
Points
You will click to button on the play.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
991
Points
When I print any document the printer prints on the right side
of the paper and would like to know how to set the page to
print on the middle of the paper.
1 Related Answer
Anonymous
  • 1751 Answers
  • Posted on Nov 04, 2010
SOURCE: I'm using CANON LBP 3300
Hi
you need to change your printer settings
from printer menu
In case I hade help you pls vote me
Hi when I use the Canon LBP 3300, if i give a print coomand for A4 it asks the paper to be loaded in manual slot, whreras I alwzys want the printer to always use the tray, whatever be the size of the paper...
Hi
Go to the control panel and select printer and faxes, right click your printer and select properties, click printing preference , select paper quality in the colume sources is select "auto seletc" and click Ok
now your problem is fix.
Cheer
10helpful
2answers
Canon LBP 3300 printer A4 Paper is already loaded in Cassatt 1 but "Load custom paper in manual feed slot" massage shown when given print comment
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
1helpful
2answers
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
1helpful
Load custom paper in manual feed slot.
Change paper source in preferances to casette 1. Now it is ok.
5helpful
4helpful
Printer not taking paper from cassette
If this printer have control pannel then open menu then finde out factory stting ,set default it and save it other wise remove printer s/w and install again
1helpful
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
6helpful
2answers
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
old marine
old marine
ZJ Limited
ZJ Limited
