Question about GE JVM1440 Microwave Oven
Everything (electronically) works, but doesn't heat. Yesterday autistic son opened while it was running & husband accidently bumped door from underneath - suggestions! and thanks!
  • sbreaux10 Sep 16, 2010
    read other reviews that said door jam could be issue with this type of problem...what about that? thanks!
  • 2,299 Answers
It is typically the magnetron. It typically fails and shorts out, causing the oven to not heat. Not worth fixing since the cost of the magnetron is typically as much as a new oven.
Posted on Sep 16, 2010
  • 1,555 Answers
Sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnatron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnatron, they replace the whole oven.
There is a possiblity that the circuit that provides power to the magnatron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it appart. It is a fairly lengthy process however.
  • Aruna Singh
    Aruna Singh Sep 16, 2010
    It's your wish. If you wan't to put in any more repair cost on this article. As an expert that was my advise and I stand on it.
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Microwave Ovens
Sometimes when I go to heat something in the microwave it doesn't heat but when I open the door and then close it it sometimes will work?
Sounds like the door switch is going bad this is the switch that "tells" the microwave the door is closed so that way it doesn't run with it open
Apr 26, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
My husband heated up something in the microwave and when he took his food out he bumped the latch and broke it and then shut the door. Now we can't even get it open. How do I open the door so I can see...
You would need a new "door latch". It's a pretty easy do it yourself job.
You can look it up and find helpful exploded views by entering model number (as FMT118E1W0) at the Pros' site here.
You have to separate the door panels (as shown in the attached photo).
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jan 11, 2011 | Frigidaire FMT118E1W Microwave Oven
Fuse in Microwave blew , now starts running when door is opened
You have one or more defective door switches, or the door switch mount is loose or damaged. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 23, 2007 | GE JE1540 Microwave Oven
Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Dec 21, 2006 | Maytag MMC5000 Microwave Oven
GE JVM1440 Microwave Oven Logo
26 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
