Question about Casio Parts Cash Register PC Desktop
Hi Flexion. You are right since the problem of not working ERR. CORR/CANCEL and X multiplication buttons existed since before (only noticed now) but the amount limitation error happens right after setting-up the trainee clerk. When inputing less than 1.00 amount then press the item, it gives a long beeping sound then goes back to 0.00, so i dont even reach the stage of pressing CASH. Please help. Thanks.
  • 737 Answers
To change the keyboard, Turn key to program 4 SUBTOTAL 082 Now press the position where you want the X multiply button 034 Now press the position where you want ERR CORR button SUBTOTAL
as for the amount limitation, try it on the item that you set as 0 last time (3 SUBTOTAL 0 item SUBTOTAL). I need to know if it affects all items or whether any items you set as 0 above will work at less than $1.00. I don't think it has anything to do with training mode. Probably has a limit set from previous owner
Posted on Sep 19, 2010
How do i do a void on a casio ce-2300 cash register?
There are two ways to reverse an entry. If you have just entered the item and have not yet pressed any other button, then ERR CORR will remove it. Otherwise, use refund (RF), then type price and press the department you used. this will remove that amount from the specified department.
If anyone needs more information, C-tech collective have the Casio CE-2300 user/ programming manual here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-2300_operators_manual.html
Mar 12, 2011 | Casio Parts Cash Register PC Desktop
I have a casio te 4000f and it will not let anyone ring in when sub total pressed it is counting down in 1p also saying buffer full??? help
Ok. See if you can get rid of the buffer full error for a start. try pressing clear (C) then press Subtotal. You should see an amount on the display. Now press the ERR CORR/ CANCEL button. This should stop the sale that you are stuck in.
Turn the key to Program mode. If it gives error as you turn the key, then you haven't finshed in REG, turn back to REG and try to end the sale first.
If you see P01 on the display, it has worked and then do this:
1 SUBTOTAL 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL.
Now turn back to REG and try it.
If it still didn't work, let me know what happened, and I'll show you another method
If anyone needs a Casio TE-4000F manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Jan 29, 2011 | Casio Parts Cash Register PC Desktop
Flexion1. The keyboard orientation is different from the keypad template. The X multiply is located in button 4 under RECEIPT FEED and ERR. CORR/CANCEL is on button 3. Better if it will be back to the same...
Sep 17, 2010 | Casio Parts Cash Register PC Desktop
Flexion1, Thank you for solving the problem E026 ENTER CONDIMENT/PREPARATION PLU. Please help me with the other; why is it that an amount less than <1.00 is not accepted to make a transaction, it just...
This makes no sense. they are all unrelated problems. Did all of these problems suddenly happen when you changed clerk settings? Try logging on as another clerk. They are in totally different areas of programming. I'm getting some information together for these problems. As for the amount limitation problem, do you get the error when you press the item, or only when you try to press CASH at the end of the sale?
Sep 15, 2010 | Casio Parts Cash Register PC Desktop
Flexion1, Many thanks for getting back to me. I guess better not to use the trainee instead. The solution did not solve the problem. Still the message E026 ENTER CONDIMENT/PREPARATION PLU appears on the...
Oh right. sorry, the last part of your question was cut off, so I didn't see all of it. It looks like you have accidentally set limitations and preparation status on a PLU.
Firstly, you need to jump out of preparation status. Follow this carefully:
Turn key to PROGRAM mode. (don't worry if error/ beeping) Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL and wait for printout. 3 SUBTOTAL (if you see error 8, you need to sign back on) 0 Now press the item button that gave you the error SUBTOTAL
Now go to REG mode and try that PLU (item). If it is doing it on any item or only when you press a payment, let me know
Sep 14, 2010 | Casio Parts Cash Register PC Desktop
ERR comes on screen...
Pull all the batteries, wait 30 seconds, put in a completely different card, put batteries back in and turn on and format the card--sometimes works
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Casio Parts Cash Register PC Desktop Logo
37 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
