Question about Cameras
Flash attachment for minolta maxxum 7000
There I was, just taking pictures with the aid of the flash attachment when it stopped working. Changed the batteries-twice-just to be sure. Unit seems to power up, all lights on (except green "OK"), lightning bolt flashes in viewfinder upon activation, but when I take the picture, the flash doesn't flash!! I cleaned the contacts on the shoe-HELP! Don't know what else to do except give it a vertical adjustment. . .
  • 22 Answers
If all the ready lights come on and the unit will not flash there is a good chance that either the flashtube is burned out or broken or there is a problem in the trigger circuit. There can also be a problem in the contacts on the unit or in the camera.
The camera’s internal synchronization mechanism can be burned out, carbonized or broken down.
Neither of theses problems are a do-it-yourself project unless you are a trained camera repair person (in the case of the camera) or a qualified electronic technician with experience in high voltage devices. Electronic flash units harbor dangerous and eve lethal voltages which can cause a great deal of harm or even death.
Tests you can do: If the flash unit has its own trigger button, try it and see if it fires. You can place a metal screwdriver across the terminals at the bottom of the flash unit and see if that will fire the unit. If those procedures work then the problem is in the camera. Try the camera with another flash unit- if that works the problem is in the flash unit.
If you are using a digital camera make sure to use a trigger voltage protective device between the camera and the flash. Older flash units can harm the circuitry in digital cameras due to their higher amounts of voltage coming through the camera’s shutter.
A visit to you local camera shop may help sort out the problem. If there is a problem, the can sent the camera or the flash in for repair.
I hope this helps. Ed
Posted on May 28, 2008
Aoutofocus stopped working
Please remove the battery and and then insert it again and test to automatically reset the setting.
melnavz
Oct 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 7000 wont turn on, I already changed batteries, the cr2016 andcleaned contacts.
Hi, If you're sure the batteries are new and working it's hard to say what could be wrong. If you're looking to have it looked at and repaired I'd suggest talking to Gus Lazzari, he's a wizard with 35mm cameras.
Jun 14, 2011 | Minolta Maxxum 7000 35mm SLR Camera
I have minolta maxxum 7000 35mm slr camera, i have a problem with it, that when i take picture they come out too dark to see. why do this happen with the pictures?
Set your exposure mode to either P ( Program ) and take pictures.
If the picture still come out dark, you have the meter cells that are bad.
Jun 04, 2010 | Minolta Maxxum 7000 35mm SLR Camera
What year was the Minolta Maxxum 7000, serial number 16043985? Thanks, Karla
I do not know for certain. You might find that answer on the Yahoo Minolta groups.
The Maxxum 7000 was introduced to the US market in 1985. Sold as the Alpha 7000 in Japan and Dynax elsewhere, it was replaced by the 7000i in a couple years. Then the 700, the 700xi, the 700si, the 70 and the 7 was the last film based 7 series. There
They also made 8000i, 800si, etc. The 9 series was the Minolta Professional cameras and they had the toughest bodies, weatherproofing, higher shutter speeds, and more.
Later models introduced better autofocus, better exposure options, wireless flash, faster film advance, etc.
lightspiritphotography.com
Nov 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Bad Minolta Maxxum lens?
Oddly enough, the camera and lens are working just fine now - or at least they appear to be. I'll shoot some more when I have good lighting and 1-hour them tomorrow for the results.
Nov 24, 2008 | Konica Minolta Maxxum QTsi with 35-80 lens...
Minolta 7000 Maxxum
The Minolta Maxxum 7000 uses a Minolta A mount, which is also used on the Sony Alpha series, as they bought out Minolta's technology. All Maxxum lenses should work for the most part on the Sony Alpha series of DSLR's, including the autofocus.
-John
Sep 15, 2008 | Tamron 28-300mm f/3.5-6.3 XR Lens for...
Minolta Maxxum 7000
ONline manual from Minolta says "winding motor problem", try removing battery and reinstalling. It didn't work for me though.
Jul 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera not working
Dear Minolta friends,
I have recently bought a second hand Maxxum 7000 and a AF lens, but found the body not ocntrolling the aperture while shooting. I know 7000 has someting special. Is my problem is due to lens and body compatibility or actually the malfunction of the body. I am sure the AF lens is ok since i have tried it working with another minolta af body.
Can give me an advice?
Aug 02, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Cameras Logo
313 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
