Question about Konica Minolta bizhub 180 All-In-One Printer
Our bizhub 180 is showing prn err - Konica Minolta bizhub 180 All-In-One Printer
    President:
  • Konica Minolta Expert
  • 347 Answers
First of all check the error.what error is appearing on the display.if it is about the paper size error then check the paper size in the tray. then adjust the paper size from your computer where you installed the driver, adjust the paper size from printing preferences by right clicking on the printer icon.then in paper size tab you can adjust the paper size. paper size must be the same as in the tray.
Posted on Sep 26, 2010
Pint light keeps blinking error light is on screen show "A 1 C prin err
loose USB cable usually the problem in bizhub180, check / reinsert .
Sep 18, 2015 | Konica Minolta bizhub 180 All-In-One...
WHAT IS THE COURSE OF HAVING THIS ERROR CODE 14H.HOW CAN I HELP TO SOLVE THIS PROBLEM
Went thru the Bizhub 180 service manual and operators manual no H14. What model machine do you have
Oct 02, 2014 | Konica Minolta bizhub 180 All-In-One...
What would be the genuine problem when konica minolta bizhub 215 shows maintainence call(m2)
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Apr 03, 2014 | Minolta bizhub 180 Black and White Copier
Two day ago i managed to print on a Konica Minolta Di1611, and now it's giving me "PRN ERR" message and "LOAD suitable paper", even though I'm using the same type of paper. I tried to...
is the driver set correctly with the type of paper you have loaded in the draw also when you select the the job to print is it correct in the properties showing the correct type of paper and what draw it is taking it from
Jan 08, 2011 | Minolta Bizhub Di1811p Copier
I have an old Konica Minolta bizhub 180 and am trying to make a copy on an 18x11 inch piece of paper with no success. Can anyone help me out?
The maximum paper size for the Bizhub 180 was 11"X17". Using a larger paper size will result in either incomplete copy or a paper jam every time.
Good Luck and Thank You for using Fixya.
Oct 14, 2010 | Konica Minolta bizhub 180 All-In-One...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
Unable to print from after attching to dlink printer server
check the paper type in the driver, it might be setted to Letter and you are trying to print as A4 or A4 to letter.
Jun 09, 2009 | Konica Minolta bizhub 180 All-In-One...
PRINT ENVELOPES
You MUST use the bypass tray and bve sure to enter the custom size, media type and weight in the driver. The settings MUST be set the same on the 180 before printing.
Running envelopes is a tricky situation, but once mastered it should work. Note that not all envelopes will run, try different sizes and brands and keep the ones that work.
Nov 16, 2007 | Konica Minolta bizhub 180 All-In-One...
Konica Minolta bizhub 180 All-In-One Printer Logo
866 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
