Question about D-Link Computers & Internet
Hello sir i have a d link2730 B modem +router but problem is my d link CD is broken i want to change my net work scqerty so can u help me plz
Helo sir I have a d-link modem...and I connect it to my hub....to share to my other computer....but it wont work...plzz help.
Posted on Jul 16, 2012
  • 700 Answers
SOURCE: unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
Posted on May 22, 2009
niquose
  • 198 Answers
SOURCE: forgotten password for D-Link DSL G604T wireless router
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
Posted on Jun 25, 2009
YourZEN
  • 820 Answers
SOURCE: Belkin N Wireless Modem-Router F5D8633 drivers
Belkin product support for F5D8633:
http://www.belkin.com/uk/support/product/?lid=en&pid=F5D8633uk4A
Posted on Sep 12, 2009
  • 1341 Answers
SOURCE: Hello! I have D-link DSL-321B moidem.
Basically connect your modem to your router with the right cable connections.Then from the router you can customized your wireless connection name, encryption etc.Now from this router you can connect several pcs either by ethernet cable or via wireless if you can set it up.Now if you are trying to connect a few more pcs wired to the router and there is not enough space then cheapest thing is to get wireless pci card for the pcs(assuming they are desktops and not laptops).I hope I have answered your question here.
Posted on Feb 11, 2010
  • 355 Answers
SOURCE: hughes net and Dlink address conflict
the default user name is admin and the password field should be left blank. if that does not work to get back in you will have to reset your router to factory defaults. to do this follow these instructions.
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do
the following:
• Leave the device powered on, do not disconnect the power
• Press the reset button and hold (use a paper clip)
• Keep the button pressed about 10 seconds
• Release the button
The DI-514 will then automatically reboot itself.
at this point the factory default ip address is 192.168.0.1 the user name is admin and the password field should be left blank as mentioned before.
Posted on Apr 24, 2010
How to download the bluetooth? and how to install in the desktop
hello how are?
sir can you tel me plz!
how can i setup the modem without CD
Jan 20, 2011 | Computers & Internet
Hello Sir I m frm India n I have this modem.The problem is that it cannot open some page using this modem D-Link DSL-302G (ADSL modem).I first thought that it is due to the OS that I had installed in the...
Hi Piyush,
Have you tried changing MTU settings in your modem?
Try that,that can solve your problem.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link DSL 302G (DSL-302G) Modem
Good day sir madam pls help me for my d-link router model DI-704P i need the driver...where can i get my driver through internet?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 03, 2010 | D-Link DI-704P Router
I have lost Installation CD I would like to know
Hello there!
Here you go.
http://www.dlink.com/corporate/worldwideoffices/?redirect=%2fdefault.aspx
Thats big manufacturer you should find what you need in download section.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | D-Link AirPlus DI-524 Wireless Router
CAN NOT GET INTERNET FROM DIR-655 TO NS7000S
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Yes I have a linksys wireless-G WRT54G router. and I hooked it up correctly to my modem and computer ect. Followed the instrustions on the CD but after the set up wiz got done configuring it and it tried...
Then you need to connect the computer to the router and the modem to the router.
Feb 13, 2010 | Linksys Wireless-G Broadband Router
Computer won't go onto the net.
Are you trying to install the router.
MAke sure that your computer is able to go online
through the modem.
modem
ad the modem to the router.
Click Here for step by step by instructions
Jan 10, 2010 | D-Link AirPlus DI-524 Wireless Router
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Jan 26, 2009 | Arris Touchstone 450a (CM450) Modem
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Computers & Internet Logo
71 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
