Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
What is a shaft key and where is it located on the Poulan Pro riding law mower
    Brigadier General:
  • 3,911 Answers
The shaft key is a weaker link allowing independent spin in the event of a catastrophy. Your engine is spinning and a blade is halted by a stump or block. Something has to give and the key is that something instead of inertia curling your driveshaft. You will find one of these on the engine's crankshaft, and one on each side of the rear axle. If you fail to insert it on reassembly you will be freewheeling.
Posted on Sep 16, 2010
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Diagram oof a poulan pro riding mower
look behind where the key is only place I've ever sen one
Jul 24, 2014 | Poulan Garden
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
Poulan pro pr185h42st How do I remove the steering column
Do you have the tractor operator's manual? There are parts diagrams in the back. If not, here is a typical Poulan Pro Manual It looks like you should.
1. Remove the steering wheel.
2. Remove the steering shaft extension
3. Remove the clip from the shaft down by the steering sector.
4. At this point the steering shaft may slide out the bottom of the tractor through a hole in the frame. If there is no hole you will have to remove the complete steering sector from the tractor.
Nov 01, 2013 | Garden
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
Poulan pro 300ex riding lawn mower
pull the top cover and see if the starter gear broke if so napa has them for about $10
May 06, 2012 | Garden
Need to locate a diode for a Poulan Pro riding mower
it is on the engine side of the two wire plug going to the engine it will only be a slight bubble in the wires
Apr 03, 2012 | Poulan Pro Garden Tractor 2005 and Older...
My 54" Poulan Pro riding mower dies when the
battery weak replace or charge, mower has electric clutch which pulls amps from battery
Jun 26, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Auto oil does not work on poulan pro 260 saw cleaned bararea
need to replace the oil pump
have to take the clutch pulley off the shaft.
Feb 27, 2011 | Poulan Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
