Question about Fuji FinePix A850 Digital Camera
There is a message while turning on the camera as " Off and On the switch once more". Camera functions after doing this.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 16, 2010
4 Suggested Answers
  • 256 Answers
SOURCE: Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
Posted on Jun 13, 2009
  • 11967 Answers
SOURCE: Message
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 27, 2010
lock123
  • 6831 Answers
SOURCE: Error message: Please turn camera off and then on
Hello
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
Nixon coolpix l810 will not turn on just replaced batteries wondering if batteries are the issue
When switching it on you have to be sure you remove the lens cap beforehand as an error message will be displayed. If you do not see an error message and the cap is off, you might not have the updated firmware version 1.1. Nikon's website states:
"When some new AA lithium batteries were inserted in the camera and the camera was turned on, the camera sometimes failed to function. This issue has been resolved."
To download go to:
http://support.nikonusa.com/app/answers/detail/a_id/18049
Jan 08, 2013 | Nikon COOLPIX L810
I just purchased this camera and inserted a memory card. Now, when I try to take a picture, I get the 'card protected' error. How do I remove this error and take pictures?
Without knowing the make and model of this new camera I can only speculate on the problem however in my opinion you need to unlock the protected card I'm giving a diagram of an SD card here.
Slide this little switch to the top or towards the gold contacts.
Another thing you will need to do is format the memory card your camera may call this initialize.
Formatting a memory card makes it ready to accept information files from the camera. I hope you have your manual because without knowing the camera make and model i can only suggest where to look for this feature. Most often this function is in the set up menu, once the card is unlocked you need to find this format highlight it and press the okay button once done the camera will function properly as long as you have set the day date and time. Day date and time once set is held in the camera internal memory so you don't have to input the information each time you turn the camera off and back on again. Happy New Year
Dec 31, 2010 | Cameras
I have just downloaded the camera on to iphoto and have cleared the camera memory . I clicked the eject icon on iphoto and once cleared unplugged the USB download cable . I have just pushed the power...
Sounds like you did two things wrong...you deleted/erased/or formatted the camera using the computer. You disconnected the camera without using the "safely remove hardware" function.
Dec 12, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Camera suddenly will not record
This looks like a relay or micro switch has gone, camera needs looking at.
Jun 20, 2010 | Panasonic NV-DS65 Mini DV Digital...
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
Please help - my lens will not come out, once I switch on my camera. It comes up with an E18 message Vicky
E18 error means that the lens mechanism is jammed and the lens cannot extend/retract.
Follow the steps provided below to solve this problem.
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on.If this does not work then try the compressed air. With a fine tip blow off gun and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function as fine.If this also does not work then you need to force the lens out .
Hope this helps.
Thanks for using Fixya.
Jan 31, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
the PLAY MODE button once to switch to Play mode and press it again to switch
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
play mode. Press the play mode button again and the camera will be turned off.
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
2. The last image stored on the memory is
displayed on the LCD monitor.
● Playing back a still image
1. Select the PLAY mode by pressing the
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Camera gives message E04. What can I do?
Sounds crazy, but It worked for me. I open up the tape door, ejected the tape. lightly squeezed the two long sides of the piece that hold the tape in place. I placed the tape back in. The tape fit slightly more snug in the cassette holder.
This worked for me.
Feb 20, 2009 | JVC GR-DVF31U Digital Cybercam GRDVF31U...
Sony cybershot DSC W50
when I turn the power on screen is blue with "access" message. after a few minutes, message is replaced with "turn power on and off". I have removed and recharged battery but keep getting the same message and other functions of the camera will not work.
Apr 30, 2008 | Sony Cybershot S650 Digital Camera
Fuji FinePix A850 Digital Camera Logo
18 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
