Question about Kenwood KM400 / KM410 Chef Classic Stand Mixer
The K Beater
There are particals of a silver grey flaking from the beater into my food can you please explain why this may be happening?
  • 417 Answers
It is most probably the nickel plating seperating of the the beater surface unless it is actually hitting the side of the bowl. You may need to replace the beater as it is not good to eat food with metal in it.
Posted on Jun 05, 2008
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Nov 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
Beater hits side of bowl
What part number did you order for the beater and what is the model number for the mixer? Also is the mixer brand new, or did you get it used and it just started happening?
Jun 17, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Can alter the height of the beater
If this is, in fact, a factory error Kenwood should be able to advise you on how to correct it
Dec 22, 2012 | Kenwood Chef Classic Km336 4.6 Litre...
I need a spare beater of moulinex supermix 170 cake beater. the grey handle beater is broken, where do i get both the grey and white handle beaters .
We have a Supermix 170 that has worn gears inside the motor unit so you can have the whole thing for spares :)
Dec 01, 2010 | Food Mixers
I cannot get the beater to lock in place. The
Hi VBPROSANDY, When you say beater, I assume you mean your flat beater. Are you having the same problem with your Wire Whip beater and dough hook? If you are not, then the first thing I’d do is look inside the flat beater’s attachment well, to see that there is nothing; i.e. hardened food, dough or batter, in the bottom of it that would prevent the agitator shaft and groove pin from seating properly. The flat beater has two drain holes at the bottom for drainage, but if these get plugged it may prevent accumulated ‘gunk’ at the bottom from escaping, and over time the buildup may prevent the beater from seating properly.
If you find the beater attachment well is clean, then from the KA Instruction manual, to attach the flat beater...
1. Slide speed control to OFF and unplug.
2. Slip flat beater on beater shaft.
3. Turn beater to left, hooking beater over the pin on shaft.
Finally, check the groove pin on the agitator shaft to make sure it hasn’t become bent so that it doesn’t fit the beater properly. Pins shouldn’t bend, but sometimes they do.
The beater attachment process should not require any effort as the agitator shaft should easily fit into the beater’s attachment well and easily turn to the left. Your planetary should not move during this process and if it does move it will take some effort on your part to turn it. The fact that you’re turning the planetary means you’ve turned the beater as far to the left as it should go to ‘lock’ it. When you get this far, let go and the beater should fall into place on the groove pin.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 06, 2009 | KitchenAid KP2671 Professional 6 Series...
I have a grey film on my flat metal beater anyway to remove?
Gray film may be a result of tarnishing. The metal beaters are made of a burnished aluminum material. The burnished aluminum may not be washed in a dishwasher, cannot be left to soak in a sink, and must be towel dried immediately after washing as opposed to being air dried. If this has been done incorrectly, this may lead to tarnishing of the beater, which can be described as a "grey film."
Jun 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Help with replacement parts
Your beater to bowl adjustment may have come out of alignment, which can happen over time with normal use of the machine. This simply means that the flat beater may be contacting the bottom of the bowl.
In your mixer's Use and Care Guide, the beater to bowl adjustment is covered and will provide easy instructions to follow about how to adjust your beater back into proper position.
There are burnished aluminum beaters available. That is to say, they do not have the food-safe nylon coating on the outside of them. Burnished aluminum beaters may not be used in the dishwasher, require hand-washing, no soaking, and immediate towel drying. Failure to follow exact washing instruction with burnished aluminum beaters may result in tarnishing of the beaters.
May 27, 2009 | KitchenAid K5SS Heavy Duty Commercial...
The head to my kitchen aid mixer bounces up when kneading dough
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Apr 05, 2009 | KitchenAid Food Mixers
Peeled beater and hook
Stan. If you were to keep these attachments soaking in alcohol (rubbing) between uses, I'd say yes, however this would probably make more coating flake off. This coating goes into the food you're mixing. Bacteria will remain between the metal part of the attachment and the plastic coating,where you can't scrub it off.
Replace them. Try to find all metal ones. While you're at it, throw out all cracked plates and coffee mugs too, as these cracks harbour bacteria that will survive normal dishwashing. If you are ever in a restaurant and are served food on a cracked plate refuse it and tell them not to just scrape the food onto another plate.
I spent 13 years in the restaurant business, anytime we came across a cracked plate cup or mug, into the trash it went. food and all. Dont take chances with your health. If you found this solution helpfull, please rate it Good luck. ricardok45
Jan 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kenwood KM400 / KM410 Chef Classic Stand Mixer Logo
216 people viewed this question
Top Kenwood Food Mixers Experts
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
