Question about ASUS F5RL-X1 Notebook
Hi,my notebook is not turning on .Charging is good .When i press switch button charging process is stopping to 1-2 seconds then continues .Maybe problems in motherboard?Product Details for ASUS F5RL-X1 T2370 1.73G 1GB 120GB DVDRW 15.4-WXGA.. I need schematic diagram of motherboard?or any help where is problem
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
    Problem Solver:
  • 16 Answers
There is schematic diagram for your laptop:laptopdesktopschematic.com. there you can read how download laptop schematic free.
Posted on Oct 23, 2010
Msi u100 motherboard
The power adapter may be falsely indicating it is charging the battery when, in fact, the battery cannot be charged.
Feb 13, 2014 | Acer Computers & Internet
TracFone is charged, but says it is not charged and will not turn on.
Hello':":":":"
PHONE CHARGING:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
2:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 20, 2013 | LG Cell Phones
My nokia n 86 is not getting switched on after charging it overnight. What can be done to it to switch it on?
First Option:
5.Wait 10 seconds.
Step
Thanks
Second option:
First Option:
Dec 07, 2012 | Nokia N86 Smartphone
Hello i have hp compaq nx9020 and when i press the power button the power led turn on for 2 or 3 seconds and then died again
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 07, 2010 | Computers & Internet
I press the power button and it does not come one
steps:
Dec 07, 2010 | HP Pavilion dv2915nr Notebook
IPhone will not turn on i have tried charging via USB on a MacBook but no luck and have tried charging via AC adapter still no luck
Here are the steps to reset the iPhone. You probably performed the first reset, try the other resets.:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Take care
Mar 25, 2010 | Apple iPhone Smartphone
My acer aspire battery
first, you must release your harddisc drive. and see what is happen for next minutes, after you insert that batteray and plug in your adaptor, to your laptop. See indicator lamp, blinking = still charging into baterai. Light ON = full charging. And charging process, see your laptop, what did you press any button for charging batteray?
If you still press any button, clean all hardware inside of bottom case and upper case.
Sometimes dirty can disturb that process.
Sep 07, 2009 | Acer Aspire 5100-5022 Notebook
Power goes off when booting ...
Hi if you had not used your notebook for sometime and kept it without charging the batt., then charge the batt fully probably for 12 or 14 hours and then switch it on .
May 24, 2008 | Fujitsu Siemens Lifebook C2230 Notebook
I can't turn on my phone ><
Try to format your phone, use the following steps.
Switch off the phone. Press phone on again. Now hold down the following three buttons: Green (call answer) button, (* )button, and '3' button. Format is complete when you see 'Choose Country' option. All your data in phone memory will belost, but your data in the memory card will still be there. if this does not work, take your phone to the service center and have it flashed
May 18, 2008 | Nokia 3250 Cellular Phone
ASUS F5RL-X1 Notebook Logo
1,441 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
