Question about Westinghouse Refrigerators
We have a westinghouse top door freezer fridge its alarm keeps goin off and isnot freezin
  • Westinghouse Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 16, 2010
Our Westinghouse virtuosa freezer alarm keeps going off. the door is definitely closed. however we did move house yesterday
When you move a fridge or freezer you need to let them stand for a couple of hours prior to turning back on again especially if you put on its side or turn it upside down.
This helps the gas in the pipes settle down I would suggest you turn it of for a couple of hours then turn it on again see if that helps.
Regards Craig
Feb 11, 2018 | Westinghouse Refrigerators
Westinghouse fridge freezer keeps alarming. Help
It is possible that there are more things wrong but my fridge freezer did that and I had to refill it with Freon gas. You need to get someone who knows what they are doing.
Jun 21, 2017 | Westinghouse Refrigerators
What do we do about a Westinghouse , vituoso where the freezer alarm keeps going off despite an expert checking and finding the fridge/freezer working perfectly well? Can the alarm be disabled?
The alarm is nothing more than a buzzer or light mechanism that is triggered by some sensor. . Disconnecting the wiring going to alarm will disable it.
Sep 25, 2015 | Westinghouse Refrigerators
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
I have a tall smeg fridge freezer. Freezer compartment working perfectly. Fridge not cooling despite all lights being on. I've switched it off then on, turned the thermostat down, then up again...
Hi Evelyn,
Has the freezer been defrosted lately? Perhaps a buildup of ice will not let the refrigerator cool sufficiently. Try this and let me know how it works out for you. If it does not have a self defrosting cycle on it, it may take some time, just do not use a sharp object in the freezer as this could puncture the freon lines and that would render the unit useless.
Joe
Sep 21, 2011 | Smeg Refrigerators
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Refrigerators Logo
169 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
